hello, why does my sim800l does not receiving message when it was compile with oled screen. This is my code
#include <SoftwareSerial.h>
#include <Arduino.h>
#include <U8g2lib.h>
#include <Wire.h> // Include the Wire library for I2C communication
#include <BH1750.h> // Include the BH1750 library
#include <Servo.h>
#include <NewPing.h>
U8G2_SSD1309_128X64_NONAME2_1_HW_I2C u8g2(U8G2_R0, /*clock=*/SCL, /*data=*/ SDA,/* reset=*/ U8X8_PIN_NONE);
BH1750 lightMeter; // Create an instance of the BH1750 sensor
// End of constructor list
#include "DHT.h"
#define DHTPIN 8// Digital pin connected to the DHT sensor
// Uncomment whatever type you're using!
#define DHTTYPE DHT11 // DHT 11
//#define DHTTYPE DHT22 // DHT 22
#define rxPin 2
#define txPin 3
#define RELAY_1 13
char str[10];
SoftwareSerial sim800(rxPin,txPin);
DHT dht(DHTPIN, DHTTYPE);
// Threshold values
#define TEMP_UPPERLIMIT 28
#define TEMP_LOWERLIMIT 5
#define HUM_UPPERLIMIT 96
#define HUM_LOWERLIMIT 10
#define LUX_UPPERLIMIT 2000.00
#define LUX_LOWERLIMIT 10.00
#define SENSOR_EXE_INTERVAL 500
#define EXE_INTERVAL 60000
unsigned long lux_lastExecutedMillis = 0;
unsigned long hum_lastExecutedMillis = 0;
unsigned long temp_lastExecutedMillis = 0;
unsigned long sensor_fetch_lastExecutedMillis = 0;
const unsigned long OneMinute = 60UL * 1000UL;
const unsigned long OneHour = 60UL * OneMinute;
const unsigned long TwentyFourHours = 24 * OneHour;
unsigned long stopTime = 1 * OneMinute;
unsigned long startTime = 0;
bool lux_ready_state = true;
bool hum_ready_state = true;
bool temp_ready_state = true;
boolean STATE_RELAY_1 = 0;
float lux = 0;
float humidity = 0;
float temp = 0;
// const String PHONE = "";
const String PHONE = "YourPhoneNumber";
String smsStatus,senderNumber,receivedDate,msg;
Serial.println(F("Hello GreMoR 2.0 !"));
Serial.println("SIM800L software serial initialize");
dht.begin();
u8g2.begin();
lightMeter.begin(); // Initialize the BH1750 sensor
Wire.begin();
if (lightMeter.begin()) {
Serial.println(F("BH1750 initialised"));
else {
Serial.println(F("Error initialising BH1750"));
Serial.println(F("BH1750 Test begin"));
pinMode(RELAY_1, OUTPUT); //Relay 1
digitalWrite(RELAY_1, LOW);
sim800.begin(9600);
sim800.println("AT+CMGF=1");
sim800.println("AT+CNMI=1,1,0,0,0");
void loop(){
// Reading temperature or humidity takes about 250 milliseconds!
float h = dht.readHumidity();
// Read temperature as Celsius (the default)
float t = dht.readTemperature();
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t) ) {
Serial.println(F("Failed to read from DHT sensor!"));
return;
float hic = dht.computeHeatIndex(t, h, false);
u8g2.firstPage();
do {
u8g2.setFont(u8g_font_helvB08);
u8g2.clearBuffer();
u8g2.drawStr( 0, 15, "GreMoR 2.0");
u8g2.drawStr( 0, 30, "Humidity:");
u8g2.drawStr( 80, 30, dtostrf(h, 5, 2, str));
u8g2.drawStr( 110, 30, "%");
u8g2.drawStr( 0, 40, "Temperature:");
u8g2.drawStr( 80, 40, dtostrf(t, 5, 2, str));
u8g2.drawStr( 110, 40, "\260C");
u8g2.drawStr( 0, 55, "Light Int:");
u8g2.drawStr( 60, 55, dtostrf(lux, 5, 2, str));
u8g2.drawStr( 110, 55, "lux");
} while( u8g2.nextPage() ); {
while(sim800.available()){
parseData(sim800.readString());
while(Serial.available()) {
sim800.println(Serial.readString());
if (!lux_ready_state && currentMillis - lux_lastExecutedMillis >= EXE_INTERVAL) {
if (!hum_ready_state && currentMillis - hum_lastExecutedMillis >= EXE_INTERVAL) {
if (!temp_ready_state && currentMillis - temp_lastExecutedMillis >= EXE_INTERVAL) {
if ( currentMillis - sensor_fetch_lastExecutedMillis >= SENSOR_EXE_INTERVAL) {
lux = get_sensor_lux();
humidity = get_sensor_humidity();
temp = get_sensor_temperature();
sensor_fetch_lastExecutedMillis = currentMillis;
if(lux_ready_state && lux >= LUX_UPPERLIMIT){
// stop wheels
Reply(create_message("Light Intensity","lux",lux));
lux_lastExecutedMillis = currentMillis; // save the last executed time
lux_ready_state = false;
if(hum_ready_state && humidity >= HUM_UPPERLIMIT){
Reply(create_message("Humidity","%",humidity));
hum_lastExecutedMillis = currentMillis; // save the last executed time
hum_ready_state = false;
if(temp_ready_state && temp >= TEMP_UPPERLIMIT){
Reply(create_message("Temperature","Celcius",temp));
temp_lastExecutedMillis = currentMillis; // save the last executed time
temp_ready_state = false;
if(STATE_RELAY_1 == 1 and startTime > 0){
//____________________________________________
if(currentMillis - startTime >= stopTime) {
STATE_RELAY_1 = 0;
startTime = 0;
void parseData(String buff) {
Serial.println(buff);
unsigned int len, index;
//Remove sent "AT Command" from the response string.
index = buff.indexOf("\r");
buff.remove(0, index+2);
buff.trim();
if(buff != "OK"){
index = buff.indexOf(":");
String cmd = buff.substring(0, index);
cmd.trim();
if(cmd == "+CMTI"){
//get newly arrived memory location and store it in temp
index = buff.indexOf(",");
String temp = buff.substring(index+1, buff.length());
temp = "AT+CMGR=" + temp + "\r";
//get the message stored at memory location "temp"
sim800.println(temp);
else if(cmd == "+CMGR"){
extractSms(buff);
Serial.println(msg);
Serial.println(senderNumber);
if(senderNumber == PHONE && msg == "get parameters"){
Reply(get_temperature());
else{
//The result of AT Command is "OK"
if(buff.indexOf("RING") > -1)
//MMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM
//+CLIP: "03001234567",129,"",0,"",0
if(buff.indexOf("+CLIP:")){
unsigned int index, index1;
index = buff.indexOf("\"");
index1 = buff.indexOf("\"", index+1);
//get phone like this format 03001234567
senderNumber = buff.substring(index+1, index1);
senderNumber.trim();
Serial.println("Caller ID: ");
//terminate the call
sim800.println("ATH");
delay(100);
//turn on the relay1
if(STATE_RELAY_1 == 0){
STATE_RELAY_1 = 1;
digitalWrite(RELAY_1, HIGH);
startTime = millis();
Serial.println("Relay 1 is ON");
//turn off the relay1
else {
STATE_RELAY_1 = 0;
startTime = 0;
Serial.println("Relay 1 is OFF");
return;
buff.trim();
//do nothing
if(buff == "OK")
{return;}
String get_temperature()
//Read temperature as Celsius (the default)
float lux = lightMeter.readLightLevel();
if (isnan(h) || isnan(t)) {
return;
//°C
String humidity = "Humidity: " + String(h) + "%";
String temperature = "Temperature: " + String(t) + " Celsius";
String light_intensity = "Light Intensity: " + String(lux) + " lux";
return humidity + "\n" + temperature + "\n" + light_intensity + "\n";
void Reply(String text)
Serial.println("Replying");
sim800.print("AT+CMGF=1\r");
sim800.print("AT+CMGS=\""+PHONE+"\"\r");
sim800.print(text);
sim800.write(0x1A); //ascii code for ctrl-26 //sim800.println((char)26); //ascii code for ctrl-26
Serial.println("SMS Sent Successfully.");
void extractSms(String buff){
unsigned int index;
smsStatus = buff.substring(1, index-1);
senderNumber = buff.substring(0, 13);
buff.remove(0,19);
receivedDate = buff.substring(0, 20);
buff.remove(0,buff.indexOf("\r"));
buff.trim();
index =buff.indexOf("\n\r");
buff = buff.substring(0, index);
buff.trim();
msg = buff;
buff = "";
msg.toLowerCase();
String create_message(String name, String unit, float value){
return name + " (" + String(value) + " " + unit + ") exceeds the threshold.";
float get_sensor_humidity(){
//Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
if (isnan(h)) {
Serial.println(F("Failed to read from Humidity sensor!"));
return 0;
return h;
float get_sensor_lux(){
if (isnan(lux)) {
Serial.println(F("Failed to read from BH1750 sensor!"));
return 0;
return lux;
float get_sensor_temperature(){
if (isnan(t)) {
Serial.println(F("Failed to read from Temperature sensor!"));
return 0;
return t;
