I'm having trouble to upload a sketch with a circular buffer. The intended size is 160,000 bytes but it will only upload when I reduce the size to 100,000 bytes.
The sketch with the reduced size will work, but I want at least 10 second of playing time in the buffer.
#define C_BUF_SIZE 100000 // 160.000 to large; is not uploading
I use the default partition scheme as defined in default.csv like this:
# Name, Type, SubType, Offset, Size, Flags
nvs, data, nvs, 0x9000, 0x5000,
otadata, data, ota, 0xe000, 0x2000,
app0, app, ota_0, 0x10000, 0x140000,
app1, app, ota_1, 0x150000,0x140000,
spiffs, data, spiffs, 0x290000,0x170000,
And the compiler output is:
Chip is ESP32D0WDQ6 (revision 1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Auto-detected Flash size: 4MB
Compressed 8192 bytes to 47...
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.0 seconds (effective 5491.1 kbit/s)...
Hash of data verified.
Compressed 17392 bytes to 11186...
Wrote 17392 bytes (11186 compressed) at 0x00001000 in 0.1 seconds (effective 992.5 kbit/s)...
Compressed 695680 bytes to 389570...
Wrote 695680 bytes (389570 compressed) at 0x00010000 in 6.0 seconds (effective 932.8 kbit/s)...
Compressed 3072 bytes to 128...
Wrote 3072 bytes (128 compressed) at 0x00008000 in 0.0 seconds (effective 1823.0 kbit/s)...
If I interpret this right then there is a:
total memory use: 47 + 11,186 + 389,570 + 128 = 400,931 bytes, which is well within the maximum of 0x140000 = 1.310.720 bytes.
So, why is this sketch not uploading?
