#include <Servo.h>
#include <Keypad.h>
#include <LiquidCrystal.h>
//servo library
Servo servo;
LiquidCrystal lcd(12, 11, 10, 9, 8, 7);
int trigPin = 1;
int echoPin = 0;
int servoPin = 13;
int led = 10;
int x;
String y;
int number = 6528;
long duration, dist, average;
long aver[3]; //array for average
String bando = "";
String strinput = "";
boolean run = true;
char input[4];
const uint8_t ROWS = 4;
const uint8_t COLS = 4;
char keys[ROWS][COLS] = {
{ '1', '2', '3', 'A' },
{ '4', '5', '6', 'B' },
{ '7', '8', '9', 'C' },
{ '*', '0', '#', 'D' }
uint8_t colPins[COLS] = { 6, 5, 4, 3 }; // Pins connected to C1, C2, C3, C4
uint8_t rowPins[ROWS] = { A0, A1, A2, A3 }; // Pins connected to R1, R2, R3, R4
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
lcd.begin(16, 2);
// you can now interact with the LCD, e.g.:
servo.attach(servoPin);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
servo.write(0); //close cap on power on
delay(100);
servo.detach();
void print(String text) {
lcd.setCursor(0,0);
lcd.print(text);
for (int scrollCounter = 0; scrollCounter < text.length(); scrollCounter++)
lcd.scrollDisplayLeft();
delay(200);
lcd.clear();
void pront(String text1, String text2){
lcd.home();
lcd.print(text1);
lcd.setCursor(0,1);
lcd.print(text2);
void measure() {
digitalWrite(10,HIGH);
digitalWrite(trigPin, LOW);
delayMicroseconds(5);
digitalWrite(trigPin, HIGH);
delayMicroseconds(15);
duration = pulseIn(echoPin, HIGH);
dist = (duration/2) / 29.1; //obtain distance
void getDistance(){
for (int i=0;i<=2;i++) { //average distance
measure();
aver[i]=dist;
delay(10); //delay between measurements
dist=(aver[0]+aver[1]+aver[2])/3;
lcd.print("Press 0 to start");
delay(10);
char start = keypad.getKey();
lcd.clear();
if (start == '0'){
lcd.clear();
print(" Welcome to the Maths Lab");
print(" This is a ATM machine");
while (run){
measure();
aver[i]=dist;
if (dist < 5){
run = false;
lcd.clear();
lcd.print("Enter the pin");
for(int i = 0; i < 5; i++){
delay(10);
input[i] = keypad.getKey();
strinput = strinput + input[i];
lcd.clear();
if (strinput == "6528"){
print("Well Done. You found the number");
print("Here's your prize");
delay(1);
servo.write(0);
delay(700);
servo.write(110);
delay(700);
servo.detach();
return 0;
delay(10);
How long has the user got to type in the 4 digit pin ?
As much time as he likes
How long will that for loop take to run ?
By the way, you are writing to element 4 of the array and that does not exist
how do i make the program wait until the user enters a number
keypad.getKey()
will always return immediately.
You have to look for a return value of NO_KEY, which means that the user did not press a key since the last time.
Stash only valid keys, not NO_KEYs. Count until you have stashed 5 valid characters, or however many you are looking for, or until a special key meaning "enter", perhaps, has been seen.
There is no need to delay(10). Also, a while loop might make better reading… while you haven't received five keypad characters, keep calling getKey.
HTH
a7
You want: input[i] = keypad.waitForKey();
