Why does the countdown increase?
Thank you for reading. My problem is in the end, the program asks for a number first, then that number is saved in the variable “t” and so that it reappears but in countdown this number appears but bigger why does this happen? for example, I put 26 and the countdown starts at 256. Thanks for reading, I use a translator since I do not speak English.
#include <Keypad.h>
#include <Wire.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(13, 12, 11, 10, 9, 8);
int t=0;
int segundostotal = 100;
int a=4;
long first = 0;
long second = 0;
double total = 0;
char customKey;
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
{‘1’,‘2’,‘3’,’+’},
{‘4’,‘5’,‘6’,’-’},
{‘7’,‘8’,‘9’,’*’},
{‘C’,‘0’,’=’,’/’}
byte rowPins[ROWS] = {7,6,5,4}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {3,2,1,0}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS);
lcd.begin(16, 2); // start lcd
lcd.setCursor(0,0);
lcd.print(“Ingrese tiempo”);
lcd.setCursor(0,1);
lcd.print(“en sg:”);
customKey = customKeypad.getKey();
if(customKey !=NO_KEY){
lcd.leftToRight();
t = (10 * t) + customKey - ‘0’;
lcd.setCursor(7,1);
lcd.print(t);
if(customKey ==’-’)
lcd.clear();
while (t > 0)
lcd.setCursor(0,0);
lcd.print(“Movimiento en:”);
lcd.setCursor(0,1);
delay (1000); //Descontamos en periodos de 1 segundo
t–;
lcd.print(t);
You enter '2' '6' '-'
t is calculated as:
t = (10 * 0) + '2' - '0' // t = 2
t = (10 * 2) + '6' - '0' // t = 26
t = (10 * 26) + '-' - '0' // t = 257
Your code does not test for customkey being a number
if (customKey != NO_KEY) {
  lcd.leftToRight();
  t = (10 * t) + customKey - '0';
  lcd.setCursor(7, 1);
  lcd.print(t);
