jcgam
October 1, 2023, 5:06am
1
2 x UNO R4 Wifi connected to USB. SCL and SDA connected via 4k7 pull up resisters. If I run this code on the slave then I2C stops. If I comment the Serial.print command in the receiveEvent function, I2C starts again (on the oscope). Why? I reversed the master/slave with the same effect.
// slave
#include <Wire.h>
char c;
Wire.begin(1);
Wire.onReceive(receiveEvent);
void receiveEvent(int bytes) {
c = Wire.read(); // read I2C
Serial.print(c);
Serial.println(c);
c = 0;
jcgam
October 1, 2023, 5:15am
2
Here's the master code:
// Arduino master
#include <Wire.h>
// Start the I2C Bus as Master
Wire.begin();
Wire.beginTransmission(1);
Wire.write("a");
Wire.endTransmission();
delay(80);
In wire.h, receiveEvent() is an interrupt service routine, and other interrupts are disabled inside of it.
Serial.print( ) requires interrupts to function so it doesn't.
you can set a marker in the receiveEvent() and print in loop only.
// slave
#include <Wire.h>
char c;
volatile bool somethingNewCameIn = false; // a marker to indicate if we have received new data
Wire.begin(42);
somethingNewCameIn = true; // set receive marker
if (somethingNewCameIn) {
Serial.println(c);
somethingNewCameIn = false; // reset receive marker
//delay(1000);
by the way, don't use a reserved addresses like 1.
Therefore I changed it to 42 (something from 8 to 119)
system
Closed
March 29, 2024, 7:51am
5
