I am trying to implement a countdown timer showing how many seconds, minutes, hours, and days are remaining. The LCD is used for showing the remaining time.
However, the issue I am facing is that the timer shows a few seconds to a few minutes (depending on how long the countdown is) even after the time passes in real life. For example, if I set the timer for 1 hour, it shows that there are 30s remaining even though an hour has passed (using phone and clock as reference). The amount of time remaining seems to be proportional to the length of the countdown timer (longer countdown -> longer time remaining after completion)
My guess is that the code takes up some time each time the loop is run, but that interval seems to be too small to cause such an observable difference. Please advise on what could be the possible reason for this
Thanks a lot in advance!
I followed the schematic shown on the official page (https://docs.arduino.cc/learn/electronics/lcd-displays) to set up the LCD. The following is the code I used to countdown:
#include <LiquidCrystal.h>
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
int S = 0; // count seconds
int M = 0; // count minutes
int H = 1; // count hours
int D = 0; // count days
int sec_to_min = 60;
int min_to_hour = 60;
int hour_to_day = 24;
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("hello, world!");
S--;
if (S < 0) {
M--;
S = sec_to_min-1;
if (M < 0) {
H--;
M = min_to_hour-1;
if (H < 0) {
D--;
H = hour_to_day-1;
M = min_to_hour-1;
S = sec_to_min-1;
lcd.setCursor(0, 1);
if (D < 0) {
lcd.print("Countdown Finished");
while(1){
} else if (D < 10) {
lcd.print("0");
lcd.setCursor(1,1);
lcd.print(D);
lcd.print(D);
lcd.setCursor(2, 1);
lcd.print("D ");
if (H > 9) {
lcd.setCursor(4, 1);
lcd.print(H);
lcd.print("0");
lcd.setCursor(5, 1);
lcd.print(H);
lcd.setCursor(6, 1);
lcd.print("H ");
if (M > 9) {
lcd.setCursor(8, 1);
lcd.print(M);
lcd.print("0");
lcd.setCursor(9, 1);
lcd.print(M);
lcd.setCursor(10, 1);
lcd.print("M ");
if (S > 9) {
lcd.setCursor(12, 1);
lcd.print(S);
lcd.print("0");
lcd.setCursor(13, 1);
lcd.print(S);
lcd.setCursor(14, 1);
lcd.print("S");
