Why does this EC sample sketch use an output?
I'm new to the whole programming business. and when i was looking at a sample sketch for a EC meter it uses an output pin. Can someone explain to me in simple terms why it does this?
Because I would like make this code smaller so i just have an output only.
Thanks
const int analogInPin = A1;  // Analog input pin that the sensor output is attached to
const int analogOutPin = 9; // Analog output pin that the LED is attached to
int sensorValue = 0;        // value read from the sensor
int outputValue = 0;        // value output to the PWM (analog out)
  // initialize serial communications at 9600 bps:
  // read the analog in value:
  sensorValue = analogRead(analogInPin);
  // map it to the range of the analog out:
  outputValue = map(sensorValue, 0, 1023, 0, 5000);
  // change the analog out value:
  analogWrite(analogOutPin, outputValue);
  // print the results to the serial monitor:
  Serial.print("sensor = " );
  Serial.print(sensorValue);
  Serial.print("\t output = ");
  Serial.println(analogRead(1)* 5.00 / 1024, 2);
  // wait 10 milliseconds before the next loop
  // for the analog-to-digital converter to settle
  // after the last reading:
Is this for a Due? Even so, 5000 is too high for 12 bit PWM
I use it with a UNO
godspeed: Can someone explain to me in simple terms why it does this?
It seems to adjust the brightness of the LED in proportion to the sensor value. If you don't want that just try the code without it.
...R
godspeed: I use it with a UNO
in which case, the brightness of the LED will sawtooth up and down
Thanks for all the answers.
So do I pretty much only need to keep this:
Would I even need to have const int analogInPin = A1;?
because it just uses this line of code instead?
Thanks.
godspeed: Would I even need to have const int analogInPin = A1;?
Thanks.
Because your sketch may grow, and it's good to get into good habits soon
