Why does turning on my water pump turn my servos?
I am trying to build a car that shoots water using the esp32 with Bluetooth compatibility. Everything has been working well so far except when I turn on the water pump which forces all the servos to get set to 0 degrees no matter what their previous setting was. It seems that when these servos go to 0 degrees, they keep trying to push beyond their mechanical range of motion because they loudly buzz instead of snapping to a position. I have tried a flyback diode ( 1N5819 Schottky) across the relay switching the pump on and off but that doesn't seem to work. Also the relay I used is rated for 3V, not 5V like the one in the schematic drawing. The motor driver I am using is the L298N All 6V sources are from 4 AA batteries in series. Thanks. I will attach my schematic, code, and image of circuit:
// this header is needed for Bluetooth Serial -> works ONLY on ESP32
#include "BluetoothSerial.h"
#include <ESP32Servo.h>
Servo vertical;
Servo horizontal;
BluetoothSerial ESP_BT;
int enA = 13;
int in1 = 12;
int in2 = 14;
int enB = 4;
int in3 = 2;
int in4 = 15;
int pump = 18;
int servoPinv = 21;
int servoPinh = 23;
// Parameters for Bluetooth interface
int incoming;
  Serial.begin(19200);
  ESP_BT.begin("ESP32_Control"); //Name of your Bluetooth interface -> will show up on your phone
  ESP32PWM::allocateTimer(0);
	ESP32PWM::allocateTimer(1);
	ESP32PWM::allocateTimer(2);
	ESP32PWM::allocateTimer(3);
  vertical.setPeriodHertz(50);
  horizontal.setPeriodHertz(50);
  vertical.attach(servoPinv, 500, 2400);
  horizontal.attach(servoPinh, 500, 2400);
  pinMode (enA, OUTPUT);
  pinMode (in1, OUTPUT);
  pinMode (in2, OUTPUT);
  pinMode (enB, OUTPUT);
  pinMode (in3, OUTPUT);
  pinMode (in4, OUTPUT);
  pinMode (pump, OUTPUT);
  // -------------------- Receive Bluetooth signal ----------------------
  if (ESP_BT.available())
    incoming = ESP_BT.read(); //Read what we receive
    // separate button ID from button value -> button ID is 10, 20, 30, etc, value is 1 or 0
    int button = floor(incoming / 10);
    int value = incoming % 10;
    switch (button) {
      case 1:
        Serial.print("Backward:"); Serial.println(value);
        digitalWrite(in1, 1);
        digitalWrite(in2, 0);
        digitalWrite(in3, 1);
        digitalWrite(in4, 0);
        vertical.write(0);
        horizontal.write(0);
        Serial.print("Servo:0");
      case 2:
        Serial.print("Forward:"); Serial.println(value);
        digitalWrite(in1, 0);
        digitalWrite(in2, 1);
        digitalWrite(in3, 0);
        digitalWrite(in4, 1);
        vertical.write(20);
        Serial.print("Servo:20");
        horizontal.write(20);
      case 3:
        Serial.print("Still:"); Serial.println(value);
        vertical.write(40);
        horizontal.write(40);
        Serial.print("Servo:40");
      case 4:
        Serial.print("Left:"); Serial.println(value);
        vertical.write(80);
        horizontal.write(80);
        Serial.print("Servo:80");
      case 5:
        Serial.print("Right:"); Serial.println(value);
        vertical.write(100);
        horizontal.write(100);
        Serial.print("Servo:100");
      case 6:
        Serial.print("Pump:"); Serial.println(value);
        if(value == 1){
        digitalWrite(pump, HIGH);
        if(value == 0){
        digitalWrite(pump, LOW);
        Serial.print("Pump: done"); Serial.println(value);
      default:
        Serial.print(":(");
  analogWrite(enA, 255); // Send PWM signal to motor A
  analogWrite(enB, 255); // Send PWM signal to motor B
Monitor the servo supply voltage, during operation, with your DMM. Is the voltage steady or does it fluctuate? Servos can misbehave if their supply voltage is unsteady.
I don't know the answer. But if the pump has its own battery, you should not have the line that I crossed.
We always strive to keep electrical noise to a minimum in our circuits.
Place a kickback diode across the pump’s coil ( 1N400X ).
You can also reduce the noise that the motor puts onto the power supply wiring by putting caps across the motor and to ground to bypass noise.
motor caps
Thanks for sharing, I learned a lot
