Why does user program like Blink.ino.mega.hex trash the bootloader.
I had to erase and reprogram my Arduino Mega2560 R3 memory with Atmel studio 7 and AVRISP mkII. When I use the hex-file with bootloader, for example Blink.ino.with_bootloader.mega.hex, Arduino IDE works. But after that, if I burn a hex-file without bootloader like Blink.ino.mega.hex, the IDE stops working. IDE says timeout from AVRdude.
Isn't there addresses in hex-files, why does an user program like Blink.ino.mega.hex trash the bootloader.
Blink.ino.mega.zip (10.7 KB)
ISP programming deletes all the flash including the bootloader. use Burn bootloader and then disconnect the programmer and use the USB upload
Yes. I noticed that AS 7 erases the chip as a default. Is it possible to use IDE to upload hex-files?
LMI1:
other then normal upload over bootloader?
there is "Upload using programmer" in Sketch menu
