Why doesn't for loop work with FastLED library?
I am trying to light up a Tic-Tac-Toe grid on my 8x8 LED Matrix. I am using for loops for this task and only one (the first) LED lights up.
My code for lighting up one line of the grid:
/// FastLED - Version: 3.4.0
#include <FastLED.h>
#define NUM_LEDS 64
#define LED_PIN 7
CRGB leds[64];
const PROGMEM int LED_Matrix[8][8] =
    {0,1,2,3,4,5,6,7},
    {15,14,13,12,11,10,9,8},
    {16,17,18,19,20,21,22,23},
    {31,30,29,28,27,26,25,24},
    {32,33,34,35,36,37,38,39},
    {47,46,45,44,43,42,41,40},
    {48,49,50,51,52,53,54,55},
    {63,62,61,60,59,58,56,54}
    FastLED.addLeds<WS2812B, LED_PIN, GRB>(leds, NUM_LEDS);
    FastLED.setBrightness(25);
    FastLED.clear();
    for(int i = 0; i<=7;i++){
      leds[LED_Matrix[i][2]] = CRGB::White;
      FastLED.show();
Please help me
Thank You
Your array is in PROGMEM so you can't change it a run time
Does the code work if the array is in SRAM as normal ?
I stored it in PROGMEM because my memory would be full
I am not changing the value of the array, I am just using it
With that small sketch ?
Hello
Change the array to const PROGMEM uint8_t LED_Matrix[8][8] =
Then use leds[ pgm_read_byte( &(LED_Matrix[i][2]) ) ] = CRGB::White;
Or, judging by the content of the array, you could delete it and use a counter instead
Use a function instead?
int LED_Matrix(int x, int y) {
  if(x & 1) return x*8+(7-y);
  else return x*8+y;
leds[LED_Matrix(i,2)] = CRGB::White;
