Hi, can someone look into my code and tell my why it isnt working? It's driving me nuts
first piece of code is the code of the master device communicating with the slave device that's the second piece of code
ty <3
#include <Wire.h>
#define ADDRES 42
#define INGANG_1 2
#define INGANG_2 3
#define INGANG_3 4
#define UITGANG_1 11
#define UITGANG_2 12
#define UITGANG_3 13
byte INPUT_1=0;
byte INPUT_2=0;
byte INPUT_3=0;
byte input_ar = 0;
// ARRAY MET PINNUMMERS VOOR INPUTS
const byte inputs[] = { 2, 3, 4, 5, 6, 7, 8, 9 };
// HIER WORDT AANGEGEVEN OP WELKE PIN DE INPUT EN OUTPUT IS AANGESLOTEN, OOK WORDEN DE
// UITGANGEN GETEST
Wire.begin();
pinMode(INGANG_1, INPUT);
pinMode(INGANG_2, INPUT);
digitalWrite(INGANG_1, HIGH);
digitalWrite(INGANG_2, HIGH);
// ALLE INGAGEN WORDEN GELADEN
INPUT_1 = digitalRead(INGANG_1);
INPUT_2 = digitalRead(INGANG_2);
INPUT_3 = digitalRead(INGANG_3);
// STUREN VAN UITGANGEN (RELAIS)
if (INPUT_1 == HIGH) digitalWrite(UITGANG_1,HIGH);
else if(INPUT_1 == LOW) digitalWrite(UITGANG_1, LOW);
if (INPUT_1 == HIGH) bitWrite(input_ar, 0, 1);
else if (INPUT_1 == LOW) bitWrite(input_ar, 0, 0);
if (INPUT_2 == HIGH) digitalWrite(UITGANG_2, HIGH);
else if (INPUT_2 == LOW) digitalWrite(UITGANG_2, LOW);
if (INPUT_2 == HIGH) bitWrite(input_ar, 1, 1);
else if (INPUT_2 == LOW) bitWrite(input_ar, 1, 0);
if (INPUT_3 == HIGH) digitalWrite(UITGANG_3, HIGH);
else if(INPUT_3 == LOW) digitalWrite(UITGANG_3, LOW);
if (INPUT_3 == HIGH) bitWrite(input_ar, 2, 1);
else if (INPUT_3 == LOW) bitWrite(input_ar, 2, 0);
Wire.beginTransmission(ADDRES);
Wire.write(input_ar);
Wire.endTransmission();
#include <Wire.h>
#define ADDRES 42
#define UITGANG_0 2
#define UITGANG_1 3
#define UITGANG_2 4
const byte relais[] = { 2, 3, 4, 5, 6, 7, 8, 9};
int ttt=0;
byte c =0;
Wire.begin(42);
Wire.onReceive(receiveEvent);
Serial.write ("test");
if ( bitRead(c, 0) == HIGH) digitalWrite(UITGANG_0, HIGH);
else if (bitRead(c, 0) == LOW) digitalWrite(UITGANG_0, LOW);
if ( bitRead(c, 1) == HIGH) digitalWrite(UITGANG_1, HIGH);
else if (bitRead(c, 1) == LOW) digitalWrite(UITGANG_1, LOW);
if (bitRead(c, 2) == HIGH) digitalWrite(UITGANG_2, HIGH);
else if (bitRead(c, 2) == LOW) digitalWrite(UITGANG_2, LOW);
void receiveEvent(int howMany) {
while ( Wire.available () > 0){
byte c = Wire.read();
Serial.print(c, DEC);
