Why doesn't this code run after re-plug? Is it scared?
I have this program (Below), that runs fine the first time its uploaded and after hitting the reset button on the board, however once I unplug it and then re-plug it, no go. Iv'e tried it with an UNO and Mega.
Things I have tried include;
Multiple boards
Other power supplies, cords
Burning bootloaders
Testing both boards with "Blink" and "no delay blink" (Works fine with both under the exact same circumstances)
Le Code...
#include <MIDI.h>
// Initialize the MIDI library with default settings
MIDI_CREATE_DEFAULT_INSTANCE();
const int pins[] = {2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12};
const int numPins = sizeof(pins) / sizeof(pins[0]);
const int debounceDelay = 50; // Debounce delay in milliseconds
// Array to store the last debounce time for each pin
unsigned long lastDebounceTime[numPins] = {0};
// Array to store the last stable state for each pin
bool lastPinState[numPins] = {HIGH};
// Array to store the current reading for each pin
bool pinReading[numPins] = {HIGH};
  // Initialize MIDI communication
  MIDI.begin(MIDI_CHANNEL_OMNI);
  // Set up each pin as an input with an internal pull-up resistor
  for (int i = 0; i < numPins; i++) {
    pinMode(pins[i], INPUT_PULLUP);
    bool reading = digitalRead(pins[i]);
    if (reading != lastPinState[i]) {
      // Reset the debounce timer
      lastDebounceTime[i] = millis();
    if ((millis() - lastDebounceTime[i]) > debounceDelay) {
      // If the reading has been stable for longer than the debounce delay
      if (reading != pinReading[i]) {
        pinReading[i] = reading;
        // Determine the note number (arbitrary mapping for demonstration)
        int note = i + 60; // Mapping pin to MIDI note (C4 = 60)
        if (reading == LOW) {
          // Send MIDI Note On message
          MIDI.sendNoteOn(note, 127, 1);
          // Send MIDI Note Off message
          MIDI.sendNoteOff(note, 0, 1);
    // Save the reading for the next loop iteration
    lastPinState[i] = reading;
I'm trying to setup a MIDI pedalboard for a 1970's CONN theater organ that had an irreplaceable part go kaput on it.
Any help would be greatly appreciated!
No, it isn't scared. Chips don't have emotions (not yet, anyway) :wink:
How do you know it does not run?
Maybe add some Serial.print to check?
Does the midi player accept multiple 'begin'?
I have it in front of me at the computer right now. the "testing" i'm doing consists of me sticking a jumper wire going from ground to the pins (2-12) to simulate the key switches. When it's "working" the TX led blinks when I attach (note on) and remove it (note off).
What could possibly go wrong within these lines of your code ?
oh, it might be that debounceDelay is never reached ... :slight_smile:
debounceDelay = 50 (milliseconds) right?
That only proves it does not send anything...
It does not prove that the sketch is not running...
It would be a good idea if you would separate your debounce from your writing to midi...
Your program flow is quite difficult to follow.
Also: add Serial.print("some message") after each if and else... That will show where the program goes.
