Why doesn't' this work?
I can't figure this out.
First I am receiving this string over serial...
01511000.00
01522000.11
01533000.22
01544000.33
01555000.44
01566000.55
Each line is terminated with a CR and LF
I want to detect when the String = "&&" and parse the data for storing on a SD.
Trying this to detect the && and then print it to prove i can detect it but the if statement always evaluates as true. What is wrong with this?
Serial1.begin(9600);
String s2;
if (Serial1.available() > 0) {
String s1 = Serial1.readStringUntil('\n');
s2 = s1;
if (s2 == "&&"); {
Serial.println(s2);
Remove the semicolon:
    if (s2 == "&&"); {
Print the length of the String. I suspect it contains a CR.
I corrected the error with the ;. wildbill, think your right. How do I add the CR char in to the
if (s2 == "&&") {
Line?
if (s2 == "&&\r") {
Thanks again! That worked, i didn't realise you could do that!
