dangerousdashie:
Ok, after reading the comments on here, I decided to learn a bit more of the basics, ohm's law etc. There are a few things that I still need clarification on.
Internal Resistance of Batteries
Am I correct in saying that the internal resistance of batteries change depending on your circuit? Originally I thought you meant that coin cells have a consistent internal resistance
No, internal resistance depends on temperature, charging state, history, many things.
So just to clarify, internal resistance isn't consistent? And it's best to figure it out as I make my circuit? I'd like to know what resistors to order before I make this, but if you need to figure out the internal resistance as you make the circuit, then it seems I can't know beforehand what resistors to order. Is that correct? Or is there a way to figure it out from those graphs on the data sheet?
All you need to do is not drain more current from the battery than the datasheet says, and expect the voltage will fall a bit under max rated load
Forward Voltage
In the data sheet for the led on page 13, it shows that the forward voltage at about 5mA current is about 2.9V. So if I did ohms law which shows that it would work with a 3V battery and a 20ohm resistor. The graph doesn't show the forward voltage lower than that. Is there a way to figure out the forward voltage/current lower than that?
The diode equation applies fairly well to LEDs, ie exponential dependence of current on forward voltage untill the series resistance of the device starts to have effect. Roughly the current will double for each 26mV increase in
voltage, per diode (if a series string). Note the "roughly", device temperature has an effect, and that depends on power dissipated, ie on current.
Pulling it together
In the end, am I supposed to use a resistor that, combined with the internal resistance, gives me the sum of the resistance needed?
You are overthinking this
Am I making this more complicated than it has to be?
As I said, over thinking - you are probably overloading the cell anyway, its a hack to start with.
