Why function returns only the first value of the array?
I am trying to understand functions in Arduino. Here I wanted to print arrays maximum value, but I do not understand what is wrong, it returns only the first value. Why?
float readings[] = {2.2, 5.6, 7.64, 3.2, 1.6, 7.0, 24.36, 254.9};
  Serial.println(arrayMax(readings));
void loop() {}
float arrayMax(float array[]) {
  float maxValue = array[0];
  for (uint8_t i = 1; i < sizeof(array) / sizeof(array[0]); i++) {
    if (maxValue < array[i]) {
      maxValue = array[i];
  return maxValue;
There is no methode to access the array bounds for the passed array, you should pass it a a separate parameter.
  Serial.println(arrayMax(readings, 8));
void loop() {}
float arrayMax(float array[], uint8_t arrayLen) {
  for (uint8_t i = 1; i < arrayLen; i++) {
  return maxValue;
Ugh. It was a silly question. Thank you very much!
No, it wasn't. It was a reasonable question, based on a misunderstanding of what is passed to a function.
