Why Get Method is not working to transfer longitude and latitude.
Hello,
I am using this code for transferring GPS latitude and longitude to mySql server.
 void send_GPRS(){
          Serial.print("AT+HTTPPARA=\"URL\",\"event.esy.es/writeData.php?latitude=");
          Serial.print(latitude);
          Serial.print("&longitude=");
          Serial.print(longitude);
          Serial.println("\"");
          delay(2000);
          Serial.println("AT+HTTPACTION=0"); //now GET action
          delay(2000);
But this above code, couldn't transfer any data to my mysql database, either "0" or any value. Thats why my database is empty.
After uploading my full code into arduino. I got bellows result in the Serial Monitor.
AT
AT+CREG?
AT+SAPBR=3,1,"APN","my3g"
AT+SAPBR=3,1,"Contype","GPRS"
AT+SAPBR=1,1
AT+HTTPINIT
AT+HTTPPARA="CID",1
ATAT+CGPSIPR=9600
AT+CGPSPWR=1
AT+CGPSRST=1
AT+CGPSINF=0
AT+HTTPPARA="URL","event.esy.es/writeData.php?latitude=0.000000&longitude=0.000000"
AT+HTTPACTION=0
AT+CGPSINF=0
AT+HTTPACTION=0
AT+CGPSINF=0
AT+HTTPACTION=0
I am expecting your kind help in this project. Really I am counting this as a serious problem.
You have not shown your entire code and you have not explained why you think that a Serial.print is going to put something into a database. I cannot help you and I do not know who can.
Thank you vaj4088 for your reply.
Here I attached my full code. I am using this code for transferring GPS latitude and longitude to mySql server.But this code, couldn't transfer any data to my mysql database, either "0" or any value. Thats why my database is empty.
#include <SoftwareSerial.h>
SoftwareSerial gprsSerial(7, 8);
char aux_str[30];
char aux;
char latitude[15];
char longitude[15];
char inChar;
int index;
char inData[200];
  gprsSerial.begin(9600);
  Serial.println("Config SIM808...");
  delay(2000);
  Serial.println("Done!...");
  gprsSerial.flush();
  Serial.flush();
  start_GSM();
    delay(5000);
    start_GPS();
   read_GPS();
   delay(2000);
   send_GPRS();
   delay(30000);
 void start_GSM(){
     //Configuracion GPRS Claro Argentina
    Serial.println("AT");
    delay(2000);
    Serial.println("AT+CREG?");
    delay(2000);
    Serial.println("AT+SAPBR=3,1,\"APN\",\"my3g\"");
    delay(2000);
    /*Serial.println("AT+SAPBR=3,1,\"USER\",\"yourUser\"");
    delay(2000);
    Serial.println("AT+SAPBR=3,1,\"PWD\",\"YourPWD\"");
    delay(2000);*/
    Serial.println("AT+SAPBR=3,1,\"Contype\",\"GPRS\"");
    delay(2000);
    Serial.println("AT+SAPBR=1,1");
    delay(10000);
    Serial.println("AT+HTTPINIT");
    delay(2000);
    Serial.println("AT+HTTPPARA=\"CID\",1");
    delay(2000);
    gprsSerial.println("AT++CGPSINF=0");
    delay(2000);
 void send_GPRS(){
          delay(2000);
          delay(2000);
 void start_GPS(){
     //Configuracion en Inicializacion GPS
    Serial.print("AT");
    Serial.println("AT+CGPSIPR=9600");// (set the baud rate)
    Serial.println("AT+CGPSPWR=1"); // (turn on GPS power supply)
    Serial.println("AT+CGPSRST=1"); //(reset GPS in autonomy mode)
    delay(10000); //delay para esperar señal del GPS
 void read_GPS(){
    Serial.println("AT+CGPSINF=0");
    read_String();
    strtok(inData, ",");
    strcpy(longitude,strtok(NULL, ",")); // Gets longitude
    strcpy(latitude,strtok(NULL, ",")); // Gets latitude
    convert2Degrees(latitude);
    convert2Degrees(longitude);
 void read_String() {
      index=0;
      while(Serial.available() > 0) // Don't read unless
                                                  // there you know there is data
       if(index < 199) // One less than the size of the array
           inChar = Serial.read(); // Read a character
           inData[index] = inChar; // Store it
           index++; // Increment where to write next
           inData[index] = '\0'; // Null terminate the string
 int8_t convert2Degrees(char* input){
    float deg;
    float minutes;
    boolean neg = false;
    //auxiliar variable
    char aux[10];
    if (input[0] == '-')
        neg = true;
        strcpy(aux, strtok(input+1, "."));
        strcpy(aux, strtok(input, "."));
    // convert string to integer and add it to final float variable
    deg = atof(aux);
    strcpy(aux, strtok(NULL, '\0'));
    minutes=atof(aux);
    minutes/=1000000;
    if (deg < 100)
        minutes += deg;
        deg = 0;
        minutes += int(deg) % 100;
        deg = int(deg) / 100;
    // add minutes to degrees
    deg=deg+minutes/60;
    if (neg == true)
        deg*=-1.0;
    neg = false;
    if( deg < 0 ){
        neg = true;
        deg*=-1;
    float numeroFloat=deg;
    int parteEntera[10];
    int cifra;
    long numero=(long)numeroFloat;
    int size=0;
    while(1){
        size=size+1;
        cifra=numero%10;
        numero=numero/10;
        parteEntera[size-1]=cifra;
        if (numero==0){
    int indice=0;
    if( neg ){
        indice++;
        input[0]='-';
    for (int i=size-1; i >= 0; i--)
        input[indice]=parteEntera[i]+'0';
        indice++;
    input[indice]='.';
    indice++;
    numeroFloat=(numeroFloat-(int)numeroFloat);
    for (int i=1; i<=6 ; i++)
        numeroFloat=numeroFloat*10;
        cifra= (long)numeroFloat;
        numeroFloat=numeroFloat-cifra;
        input[indice]=char(cifra)+48;
        indice++;
    input[indice]='\0';
void toSerial()
  while(gprsSerial.available()!=0)
    Serial.write(gprsSerial.read());
AT
AT+CREG?
AT+SAPBR=1,1
AT+HTTPINIT
AT+HTTPPARA="CID",1
ATAT+CGPSIPR=9600
AT+CGPSPWR=1
AT+CGPSRST=1
AT+CGPSINF=0
AT+HTTPACTION=0
AT+CGPSINF=0
AT+HTTPACTION=0
AT+CGPSINF=0
AT+HTTPACTION=0
My database have only 3 Columns.
One is ID, and another 2 is longitude and latitude. I tested my code many different ways. Then see AT+HTPACTION=0 is not working. Got errors. Maybe there have another issues also. But I couldnt find.
I am using Elecrow SIM808 GPRS/GSM+GPS Shield v1.1 with Arduino Uno.
Divide and conquer. Can you receive and print a GPS coordinate? Can you send a test field to the database to see if the transmission is working?
Thank you aarg for your comments. I got errors for this section.
void send_GPRS(){
          delay(2000);
          delay(2000);
AT+HTTPACTION=0 is giving errors.
