Why has A-Uno rev3 two different 16MHz resonators?
I have a Duemilanove with one 16 MHz crystal. It has a FTDIO as USB serial.
Then I have a Uno rev3 with a CSTCE16M0V53-R0 resonator attached to the a328 and a atmega16u2 as USB serial with a much larger 16 MHz crystal in metal housing attached to it.
  1. Why are the resonators different? Why not use the same type for both controllers?
  2. I have never tried but is it not possible to let both microcontrollers use the one and same resonator?
Could the board be production optimized or is there a reason for this different choise of components?
/best regards
The USB serial interface chip(*) needs an accurate clock I believe to handle USB, it has a crystal,
forget what frequency.
The ATmega processor itself probably has a ceramic resonator still (to save money), rather
than quartz crystal - though boards do differ. The Duemilanova had a different USB serial
chip which derived its timing from USB I believe, so only the ATmega had a crystal and it
was quartz, much more accurate.
(*) The interface chip happens to be another AVR microcontroller as it happens.
