Just like in topic i have problem because i can compile any code and i dont know what i compile and load to WIO Terminal. For example thi is code i tried compile:
its missing Semicolon and have few miss spell but still i can compile. After i upload code Wio Terminal behave like was old program. When i check IDE/WIOTerminal using basic examples it works fine.
arduino-cli compile -b arduino:avr:uno --warnings all --output-dir ~/tmp --no-color (in directory: /home/me/Documents/sketchbook/Uno_R3/test)
In file included from /home/me/Documents/sketchbook/Uno_R3/test/test.ino:3:0:
/home/me/Documents/sketchbook/libraries/Seeed_Arduino_FS/src/SD/Seeed_SD.h:36:73: warning: overflow in implicit constant conversion [-Woverflow]
boolean begin(uint8_t ssPin = 11, SPIClass& spi = SPI, int hz = 4000000);
/home/me/Documents/sketchbook/Uno_R3/test/test.ino:6:1: error: expected ',' or ';' before 'void'
void setup(){
/home/me/Documents/sketchbook/Uno_R3/test/test.ino: In function 'void loop()':
/home/me/Documents/sketchbook/Uno_R3/test/test.ino:22:1: error: 'Aray' was not declared in this scope
Aray.priln("x")
/home/me/Documents/sketchbook/Uno_R3/test/test.ino:22:1: note: suggested alternative: 'Array'
Aray.priln("x")
Array
Used library Version Path
SPI 1.0 /home/me/.arduino15/packages/arduino/hardware/avr/1.8.3/libraries/SPI
Seeed Arduino FS 2.1.1 /home/me/Documents/sketchbook/libraries/Seeed_Arduino_FS
Used platform Version Path
arduino:avr 1.8.3 /home/me/.arduino15/packages/arduino/hardware/avr/1.8.3
Error during build: exit status 1
Compilation failed.
Watch this https://www.youtube.com/watch?v=B2Sth6UhW-o maybe you will start understand a problem. I know i have obvious erros i made them specially an i dont know what happend.
In Arduino 1.x, modifications to a read-only sketch would still be written to the appropriate tmp files and compiled. I hope that hasn't changed in 2.x?
OTOH, if you click the "upload" button after "breaking" a sketch that you compiled, the IDE will ("may?") upload the previous binary, even though the compile itself failed. The "compile failed" message can get "lost" as the info from the upload fills your window... (Hmm. I'm pretty sure I've had this happen to me, but I'm having trouble duplicating the behavior.)
