i once using thinker cad to code an button switch and it works
i am going to implemented it using a pull_up resistor and a 2 pin button switch but it doesn't work. I test it using multimeter and the switch work properly. I cannot find what i am missing here here my code and my photo of button switch. I am trying reading the forum but i cannot find the problem is it because i am using a 2 pin button switch?
const int buttonPin = 3; // the number of the pushbutton pin
const int outputPin = 4; // the number of the LED pin
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
pinMode(outputPin, OUTPUT);
pinMode(buttonPin, INPUT_PULLUP);
// read the state of the pushbutton value:
digitalWrite (outputPin, HIGH);
buttonState = digitalRead(buttonPin);
Serial.println (buttonState);
if (buttonState == HIGH)
Serial.println("ON");
if (buttonState == LOW)
Serial.println("OFF");
delay (1000);
pinMode(..,INPUT_PULLUP) sets the input pin to HIGH.
digitalWrite(..,HIGH) sets the outputPin also to HIGH.
So you switch between HIGH and HIGH ...
Usually buttons are connected to an input pin and either a fixed HIGH (3.3V or 5V) or LOW (GND) and they are debounced to enable reading their status in very short intervals and allow for a quick response on a key press or release.
I know how difficult it is as a beginner to understand what is going with debouncing etc.
Therefore I have prepared a commented sketch now; hope it is understandable:
constexpr int buttonPin = 2; // the number of the pushbutton pin
// With an UNO the digital pins 0 and 1 are dedicated to Serial
// The digital pins 3, 5, 6, 9, 10 and 11 can be used for PWM
// Therefore usually one would use 2, 4, 7, 8, 12 or 13 for
// pure digital input or output
// variables that will or may change:
byte buttonState; // variable for reading the pushbutton status
byte lastButtonState = 1; // variable that holds the last status read
// Both variables together allow it to check if the button status has changed
// since it was read the last time:
// buttonState gets the actual status in every loop though loop()
// if buttonState and lastButtonState are different,
// we know that the button has changed its state.
// If this is the case we keep the new state in lastButtonState
// and do something (depending on this new state)
// While through all following loops the actual state and lastButtonState
// are the same nothing will happen in this sketch
// setup() is called once before the software enters loop()
// We initialize the Serial communication so that
// the Serial communication is prepared and
// the controller knows which speed (Baud rate) we want for communication
// Let us use a speed rate of 115200 as that is more appropriate for
// "state-of-the-art" computers
// buttonPin is set as an input and the internal pulluo resistor is activated
// by INPUT_PULLUP. This means that the input pin is usually HIGH if not
// pulled down to Ground (if open and/or not connected to GND)
// The pull_up resistor has usually several 10 kOhm so that a shortcut to
// GND does not destroy the input port.
// If you do not like the internal pull_up you can of course use an external
// resistor with e.g. 10, 20, 30 kOhm, connect one side to 3.3V or 5V
// depending on the controller you use and the other to the input pin
// then use pinMode(Pin, INPUT); for this pin. Be aware that - if there is
// no pull_up resistor connected - the pin may "float" which leads to arbitrary
// pin states!
buttonState = buttonStatus();
// Now compare the actual value with the one we stored last time
// If they are identical -> skip the next steps
if (buttonState != lastButtonState) {
// We only come to this line if both states are different
// Now we make both values identical again
// so that we get into the if-clause only after another change
lastButtonState = buttonState;
// Now we decide what to do depending on the new state we sensed:
// We use INPUT_PULLUP and a button that "grounds" the pin only
// while it is pressed. This means that HIGH is the pin state
// if the button is not pressed and LOW means it is pressed!
// By our own definition released equals to OFF and
// pressed to ON.
// Why our own definition? Because we could define it vice versa of course
// We can define that a pressed button means OFF and released ON
// e.g. if something shall move all the time and only stop while we press
// the button. It depends on the application ...
if (buttonState == HIGH) {
// This function reads the actual button state but only changes its output
// if a "new" state is stable for at least 30 msec (hardcoded in this routine).
// The byte in front of the function name tells the compiler to return a byteis le
// which is defined in the line "return state;"
byte buttonStatus() {
// static explains the compiler that these variables shall keep their content
// after the function has been finished. So the next time it is called it
// "remembers" lastChange, state and lastState while actState is newly initialized.
// lastChange keeps the time in msec when the last status change has taken place
static unsigned long lastChange = 0;
// state keeps our "official" state
// lastState keeps the button state detected when at the time of "lastChange"
static byte state = HIGH;
static byte lastState = HIGH;
byte actState = digitalRead(buttonPin);
// if the actual state differs from the lastState
// we keep track of the new value and the time it occured
if (actState != lastState) {
lastChange = millis();
lastState = actState;
// if our official state and the new state are different AND
// the new state did not change in the last 30 msec we accept it
// as our new official state
// This way we filter bouncing of the state between HIGH and LOW
if (state != lastState && millis() - lastChange > 30) {
state = lastState;
// Here we return the official state
return state;
thank you so much it help me so much, does this more complicated code work more stable if i want to run a function inside the if state compared to the normal button code ? . I am kinda new to arduino sorry if i ask to much. But why using byte instead const int for the button?
The example I provided can be expanded of course. Functions inside the if clause will only be called once with every change of the button state.
"const int" can only be used for a value that does not change during the sketch.
A variable of type int uses two bytes while byte only uses one byte. It doesn't make a big difference. I just like to use appropriate data types...
The compiler converts byte to int where required, the other direction may become problematic if one uses negative values and/or values larger than 255...
I suggest that you buy yourself a book about C++ that provides basic knowledge... It is really worth it
