Why i can't use bdf2u8g?
bdf2u8g101.exe : The term 'bdf2u8g101.exe' is not recognized as the name of a cmdlet, function, script file, or
operable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try
again.
At line:1 char:1
  • bdf2u8g101.exe -b 48 -e 57 gamer_digits.bdf gamer_digits gamer_digits ...
  •   + CategoryInfo          : ObjectNotFound: (bdf2u8g101.exe:String) [], CommandNotFoundException
      + FullyQualifiedErrorId : CommandNotFoundException
Welcome to the Arduino forum
Has your question got anything to do with the Arduino ?
Is bdf2u8g in the Documents folder? Normally it would be in the u8glib-master/tools/font/bdf2u8g subfolder. You will need to download the U8glib library from github if you have not done that already, the version from the library manager does not include all the tools.
I'm not sure it it will work from a powershell window, normally you would use a command prompt.
Its works! thankss
