Why I could not read the other sms's except the first SMS?
I have to read the incoming SMS on my gsm module SIM900, and I want to print the sender number
and message on to serial monitor.
I first configure gsm module with AT commands and Response() function will give me the response to AT commands.
as any SMS will be in the following pattern
+CMT: "", ""
So, I first extract +CMT and after that I will take mobile number and atlast we have message body. The code I have used is
char RcvdMsg[200] = "";
int RcvdCheck = 0;
int RcvdConf = 0;
int index = 0;
int RcvdEnd = 0;
char MsgMob[15];
char MsgTxt[50];
int MsgLength = 0;
void Config() // This function is configuring our SIM900 module i.e. sending the initial AT commands
Serial.print("ATE0\r");
Response();
Serial.print("AT\r");
Response();
Serial.print("AT+CMGF=1\r");
Response();
Serial.print("AT+CNMI=1,2,0,0,0\r");
Response();
  Config();
  RecSMS();
void Response() // Get the Response of each AT Command
int count = 0;
while(1)
if(Serial.available())
char data =Serial.read();
if(data == 'K'){Serial.println("OK");break;}
if(data == 'R'){Serial.println("GSM Not Working");break;}
count++;
delay(10);
if(count == 1000){Serial.println("GSM not Found");break;}
void RecSMS() // Receiving the SMS and extracting the Sender Mobile number & Message Text
char data = Serial.read();
if(data == '+'){RcvdCheck = 1;}
if((data == 'C') && (RcvdCheck == 1)){RcvdCheck = 2;}
if((data == 'M') && (RcvdCheck == 2)){RcvdCheck = 3;}
if((data == 'T') && (RcvdCheck == 3)){RcvdCheck = 4;}
if(RcvdCheck == 4){RcvdConf = 1; RcvdCheck = 0;}
if(RcvdConf == 1)
if(data == '\n'){RcvdEnd++;}
if(RcvdEnd == 3){RcvdEnd = 0;}
RcvdMsg[index] = data;
index++;
if(RcvdEnd == 2){RcvdConf = 0;MsgLength = index-2;index = 0;}
if(RcvdConf == 0)
Serial.print("Mobile Number is: ");
for(int x = 4;x < 17;x++)
  MsgMob[x-4] = RcvdMsg[x];
  Serial.print(MsgMob[x-4]);
  Serial.print("Message Text: ");
for(int x = 46; x < MsgLength; x++)
  MsgTxt[x-46] = RcvdMsg[x];
  Serial.print(MsgTxt[x-46]);
Serial.flush();
The problem of the code is
After receiving first SMS I am getting my mobile number and message body. After that I am only getting sender number printed on to my serial monitor but not the message body.
Where It has gone wrong. I could not understood.
Please help me.......Thanks in advance.
The problem I found in the code is, we are not resetting all the variables in RecSMS function. So to solve this keep this below code before the Serial.flush() statement.
RcvdCheck = 0;
RcvdConf = 0;
index = 0;
RcvdEnd = 0;
MsgMob[15];
MsgTxt[50];
MsgLength = 0;
This will solve the problem
