Why I do not get a syntax error in this code line?
Why I do not get a syntax error in code line digitalWrite (waterPumb, LOW),
ι end this code line using comma, not using semicolon as usual.
const int analogPin = A0;    // pin that the humidety sensor is attached to
const int waterPumb = 13;   // pin that the water valve is attached to
const int threshold = 500;   // an arbitrary threshold level that's in the range of the analog input
  pinMode(waterPumb, OUTPUT);    // initialize the water valve pin as an output:
  Serial.begin(9600);   // initialize serial communications:
  int analogValue = analogRead(analogPin);  // read the value of the potentiometer:
  if (analogValue < threshold) {digitalWrite (waterPumb, HIGH); }    //if the analog value is low enough, turn on the waterPumb
delay(10000);
digitalWrite (waterPumb, LOW),          //turn on the waterPumb
  Serial.println(analogValue);                // print the analog value
  delay(20000);                               // delay in between reads
https://www.google.com/search?q=c%2B%2B+comma+operator
thank you very much!
You are welcome.
