system
#1
I am a bit confused by this strange problem which I am encountering.
If I do this:
long value = 1<<16;
Serial.println(value);
0 is printed at the console. At first I thought it might be because a long isn’t 4 bytes as the manual says. But if I do
long value = pow(2,16);
65536 is printed at the console.
If I do
long value = 1<<8;
I get the correct value (256).
My question is, why does bitshifting not work as it should? Am I doing something wrong?
Arrch
#2
0000 0000 0000 0001
Shift 1 to the left 16 times and that 1 falls off because 1 is assumed to be an int.
Edit: Better explanation below
the_marsbar:
If I do this:
long value = 1<<16;
Because the expression (1 << 16) is evaluated as an ‘int’ expression, and ints are 16-bits. You want to make sure it is done as a long via:
long value = 1L << 16;
or
long value = ((long)1) << 16;
system
#4
Arrch: Yes, if it was a 16 bit data type. However, long is 32 bit.
MichaelMeissner: Okaaaaaay. I did not know that. Thanks for clarifying.
