Why is it not possible to enter menus using the encoder?
Greetings to everybody, I am trying to implement a PID temperature control circuit begging the circuit I show in the image, I have managed to read the temperature and display the value on the lcd. However, at the time of including the encoder, I cannot switch between menus and modify the required values.
I´m using the HW-040 as rotative encoder.
I would be grateful if you could provide me with any comments or observations about where I am wrong.
/*    Max6675 Module  ==>   Arduino
 *    CS              ==>     D10
 *    SO              ==>     D12
 *    SCK             ==>     D13
 *    Vcc             ==>     Vcc (5v)
 *    Gnd             ==>     Gnd      */
#include <SPI.h>
//LCD config
#include <Wire.h>
LiquidCrystal_I2C lcd(0x3f,20,4);  //sometimes the adress is not 0x3f. Change to 0x27 if it dosn't work.
/*    i2c LCD Module  ==>   Arduino
 *    SCL             ==>     A5
 *    SDA             ==>     A4
 *    Vcc             ==>     Vcc (5v)
 *    Gnd             ==>     Gnd      */
//I/O
int PWM_pin = 3;  //Pin for PWM signal to the MOSFET driver (the BJT npn with pullup)
int clk = 8;      //Pin 1 from rotary encoder
int data = 9;     //Pin 2 from rotary encoder
//Variables
float set_temperature = 0;            //Default temperature setpoint. Leave it 0 and control it with rotary encoder
float temperature_read = 0.0;
float PID_error = 0;
float previous_error = 0;
float elapsedTime, Time, timePrev;
float PID_value = 0;
int button_pressed = 0;
int menu_activated=0;
float last_set_temperature = 0;
//Vraiables for rotary encoder state detection
int clk_State;
int Last_State;
bool dt_State;
//PID constants
int kp = 90;   int ki = 30;   int kd = 80;
int PID_p = 0;    int PID_i = 0;    int PID_d = 0;
float last_kp = 0;
float last_ki = 0;
float last_kd = 0;
int PID_values_fixed =0;
//Pins for the SPI with MAX6675
#define MAX6675_CS   10
#define MAX6675_SO   12
#define MAX6675_SCK  13
  pinMode(PWM_pin,OUTPUT);
  TCCR2B = TCCR2B & B11111000 | 0x03;    // pin 3 and 11 PWM frequency of 928.5 Hz
  Time = millis();
  Last_State = (PINB & B00000001);      //Detect first state of the encoder
  PCICR |= (1 << PCIE0);    //enable PCMSK0 scan
  PCMSK0 |= (1 << PCINT0);  //Set pin D8 trigger an interrupt on state change.
  PCMSK0 |= (1 << PCINT1);  //Set pin D9 trigger an interrupt on state change.
  PCMSK0 |= (1 << PCINT3);  //Set pin D11 trigger an interrupt on state change.
  pinMode(11,INPUT);
  pinMode(9,INPUT);
  pinMode(8,INPUT);
  lcd.init();
  lcd.backlight();
if(menu_activated==0)
  // First we read the real value of temperature
  temperature_read = readThermocouple();
  //Next we calculate the error between the setpoint and the real value
  PID_error = set_temperature - temperature_read + 3;
  //Calculate the P value
  PID_p = 0.01*kp * PID_error;
  //Calculate the I value in a range on +-3
  PID_i = 0.01*PID_i + (ki * PID_error);
  //For derivative we need real time to calculate speed change rate
  timePrev = Time;                            // the previous time is stored before the actual time read
  Time = millis();                            // actual time read
  elapsedTime = (Time - timePrev) / 1000;
  //Now we can calculate the D calue
  PID_d = 0.01*kd*((PID_error - previous_error)/elapsedTime);
  //Final total PID value is the sum of P + I + D
  PID_value = PID_p + PID_i + PID_d;
  //We define PWM range between 0 and 255
  if(PID_value < 0)
  {    PID_value = 0;    }
  if(PID_value > 255)
  {    PID_value = 255;  }
  //Now we can write the PWM signal to the mosfet on digital pin D3
  //Since we activate the MOSFET with a 0 to the base of the BJT, we write 255-PID value (inverted)
  analogWrite(PWM_pin,255-PID_value);
  previous_error = PID_error;     //Remember to store the previous error for next loop.
  delay(250); //Refresh rate + delay of LCD print
  //lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("PID TEMP control");
  lcd.setCursor(0,1);
  lcd.print("S:");
  lcd.setCursor(2,1);
  lcd.print(set_temperature,1);
  lcd.setCursor(9,1);
  lcd.print("R:");
  lcd.setCursor(11,1);
  lcd.print(temperature_read,1);
}//end of menu 0 (PID control)
//First page of menu (temp setpoint)
if(menu_activated == 1)
   analogWrite(PWM_pin,255);
  if(set_temperature != last_set_temperature)
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Set  temperature");
  lcd.setCursor(0,1);
  lcd.print(set_temperature);
  last_set_temperature = set_temperature;
}//end of menu 1
//Second page of menu (P set)
if(menu_activated == 2)
  if(kp != last_kp)
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Set   P  value  ");
  lcd.setCursor(0,1);
  lcd.print(kp);
  last_kp = kp;
}//end of menu 2
//Third page of menu (I set)
if(menu_activated == 3)
  if(ki != last_ki)
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Set   I  value  ");
  lcd.setCursor(0,1);
  lcd.print(ki);
  last_ki = ki;
}//end of menu 3
//Forth page of menu (D set)
if(menu_activated == 4)
  if(kd != last_kd)
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Set   D  value  ");
  lcd.setCursor(0,1);
  lcd.print(kd);
  last_kd = kd;
}//end of menu 4
}//Loop end
//The function that reads the SPI data from MAX6675
double readThermocouple() {
  uint16_t v;
  pinMode(MAX6675_CS, OUTPUT);
  pinMode(MAX6675_SO, INPUT);
  pinMode(MAX6675_SCK, OUTPUT);
  digitalWrite(MAX6675_CS, LOW);
  delay(1);
  // Read in 16 bits,
  //  15    = 0 always
  //  14..2 = 0.25 degree counts MSB First
  //  2     = 1 if thermocouple is open circuit
  //  1..0  = uninteresting status
  v = shiftIn(MAX6675_SO, MAX6675_SCK, MSBFIRST);
  v <<= 8;
  v |= shiftIn(MAX6675_SO, MAX6675_SCK, MSBFIRST);
  digitalWrite(MAX6675_CS, HIGH);
  if (v & 0x4)
    // Bit 2 indicates if the thermocouple is disconnected
    return NAN;
  // The lower three bits (0,1,2) are discarded status bits
  v >>= 3;
  // The remaining bits are the number of 0.25 degree (C) counts
  return v*0.25;
//The interruption vector for push button and rotary encoder
ISR(PCINT0_vect){
if(menu_activated==1)
  clk_State =   (PINB & B00000001); //pin 8 state? It is HIGH?
  dt_State  =   (PINB & B00000010);
  if (clk_State != Last_State){
     // If the data state is different to the clock state, that means the encoder is rotating clockwise
     if (dt_State != clk_State) {
       set_temperature = set_temperature+0.5 ;
     else {
       set_temperature = set_temperature-0.5;
  Last_State = clk_State; // Updates the previous state of the clock with the current state
if(menu_activated==2)
       kp = kp+1 ;
     else {
       kp = kp-1;
if(menu_activated==3)
       ki = ki+1 ;
     else {
       ki = ki-1;
 if(menu_activated==4)
       kd = kd+1 ;
     else {
       kd = kd-1;
  //Push button was pressed!
  if (PINB & B00001000) //Pin D11 is HIGH?
    button_pressed = 1;
  //We navigate through the 4 menus with each button pressed
  else if(button_pressed == 1)
    menu_activated = 0;
    PID_values_fixed=1;
    button_pressed=0;
    menu_activated = menu_activated + 1;
    button_pressed=0;
    kd = kd + 1;
    button_pressed=0;
    ki = ki + 1;
    button_pressed=0;
    kp = kp + 1;
   if(menu_activated==0 && PID_values_fixed != 1)
    button_pressed=0;
    set_temperature = set_temperature+1;
   PID_values_fixed = 0;
Is your question about temperature and PID or reading the encoder and the menu system? Your thread title should reflect what you really want help with.
Why not use the Encoder library to read the encoder? It works really well and is proven.
There should be a resistor between pin 5 and the BJT transistor base to limit base current.
about encoder reading and menus, I still don’t implement the BJT part but I will take your comment into consideration.
The question is, is there a problem in the code or in the encoder circuit that does not allow you to enter the menu?
Congratulations this is the very first frizzy picture that I can actually read in seconds without having to look up everything. You can substitute an N-Channel MOSFET for the BJT, if staying with the BJT add a resistor in the base line. In either case pull D5 to ground so your thing does not get hot during reset etc.
Thank you for your comments, what do you mean by D5?
My favorite way to use an encoder sketch:
#define ClockPin 2 // Must be pin 2
#define DataPin 3 // Must be pin 3
#define readA bitRead(PIND,2)//faster than digitalRead()  (((value) >> (bit)) & 0x01)
#define readB bitRead(PIND,3)//faster than digitalRead()  (((value) >> (bit)) & 0x01)
volatile long count = 0;
long lastCtr;
unsigned long SpareCycles;
void Encoder(bool A) {
  (readB == A)  ? count++ : count--;
  Serial.begin(115200); //115200
  pinMode(ClockPin, INPUT);
  pinMode(DataPin, INPUT);
  /* 1 Step */
  attachInterrupt(digitalPinToInterrupt(ClockPin), [] {Encoder( true);}, RISING);
  /*  2 step count
  attachInterrupt(digitalPinToInterrupt(ClockPin), [] {Encoder( readB);}, CHANGE);
  /* Full 4 Step Count
  attachInterrupt(digitalPinToInterrupt(DataPin ), [] {Encoder( !readA);}, CHANGE);
  long Counter;
  SpareCycles++;
  noInterrupts ();
  Counter = count;
  interrupts ();
  if ((lastCtr != Counter) & (SpareCycles > 10)) {
    Serial.println(Counter);
    SpareCycles = 0;
  lastCtr = Counter;
also consider adding 2) 0.1uF caps here and here across clock to ground and data to ground to eliminate bounce :
Encoder
Z
The pin going to the base of the transistor.
Z
Very clear drawing and explanation.
Thanks zhomeslice
