I tried putting two codes together. One is for leds that if you press a button it switches to a different led bulb. The other is for my robot to follow humans. They worked fine alone, but when put together, I get errors. 'buttonState' was not declared in this scope. 'rotateMotor' was not declared in this scope.
#include <NewPing.h>
#define ULTRASONIC_SENSOR_TRIG 11
#define ULTRASONIC_SENSOR_ECHO 12
#define MAX_FORWARD_MOTOR_SPEED 75
#define MAX_MOTOR_TURN_SPEED_ADJUSTMENT 50
#define MIN_DISTANCE 10
#define MAX_DISTANCE 30
#define IR_SENSOR_RIGHT 2
#define IR_SENSOR_LEFT 3
#define LED_1_PIN 5
#define LED_2_PIN 10
#define LED_3_PIN 9
#define BUTTON_PIN 4
#define LED_NUMBER 3
byte LEDPinArray[LED_NUMBER] = { LED_1_PIN,
LED_2_PIN,
LED_3_PIN };
unsigned long debounceDuration = 50; // millis
unsigned long lastTimeButtonStateChanged = 0;
byte lastButtonState = HIGH;
int LEDIndex = 0;
void initAllLEDs()
for (int i = 0; i < LED_NUMBER; i++) {
pinMode(LEDPinArray[i], OUTPUT);
void powerOnSelectedLEDOnly(int index)
if (i == index) {
digitalWrite(LEDPinArray[i], HIGH);
else {
digitalWrite(LEDPinArray[i], LOW);
//motor code starts here
//Right motor
int enableRightMotor=5;
int rightMotorPin1=7;
int rightMotorPin2=8;
//Left motor
int enableLeftMotor=6;
int leftMotorPin1=9;
int leftMotorPin2=10;
NewPing mySensor(ULTRASONIC_SENSOR_TRIG, ULTRASONIC_SENSOR_ECHO, 400);
pinMode(enableRightMotor, OUTPUT);
pinMode(rightMotorPin1, OUTPUT);
pinMode(rightMotorPin2, OUTPUT);
pinMode(enableLeftMotor, OUTPUT);
pinMode(leftMotorPin1, OUTPUT);
pinMode(leftMotorPin2, OUTPUT);
pinMode(IR_SENSOR_RIGHT, INPUT);
pinMode(IR_SENSOR_LEFT, INPUT);
rotateMotor(0,0);
//led setup here
initAllLEDs();
pinMode(BUTTON_PIN, INPUT_PULLUP);
digitalWrite(LEDPinArray[LEDIndex], HIGH);
int distance = mySensor.ping_cm();
int rightIRSensorValue = digitalRead(IR_SENSOR_RIGHT);
int leftIRSensorValue = digitalRead(IR_SENSOR_LEFT);
//led loop code here
unsigned long timeNow = millis();
if (timeNow - lastTimeButtonStateChanged > debounceDuration) {
byte buttonState = digitalRead(BUTTON_PIN); }
if (buttonState != lastButtonState) {
lastTimeButtonStateChanged = timeNow;
lastButtonState = buttonState; }
if (buttonState == HIGH) { // button has been released
LEDIndex++;
if (LEDIndex >= LED_NUMBER) {
LEDIndex = 0;
powerOnSelectedLEDOnly(LEDIndex);
//NOTE: If IR sensor detects the hand then its value will be LOW else the value will be HIGH
//If right sensor detects hand, then turn right. We increase left motor speed and decrease the right motor speed to turn towards right
if (rightIRSensorValue == LOW && leftIRSensorValue == HIGH )
rotateMotor(MAX_FORWARD_MOTOR_SPEED - MAX_MOTOR_TURN_SPEED_ADJUSTMENT, MAX_FORWARD_MOTOR_SPEED + MAX_MOTOR_TURN_SPEED_ADJUSTMENT );
//If left sensor detects hand, then turn left. We increase right motor speed and decrease the left motor speed to turn towards left
else if (rightIRSensorValue == HIGH && leftIRSensorValue == LOW )
rotateMotor(MAX_FORWARD_MOTOR_SPEED + MAX_MOTOR_TURN_SPEED_ADJUSTMENT, MAX_FORWARD_MOTOR_SPEED - MAX_MOTOR_TURN_SPEED_ADJUSTMENT);
//If distance is between min and max then go straight
else if (distance >= MIN_DISTANCE && distance <= MAX_DISTANCE)
rotateMotor(MAX_FORWARD_MOTOR_SPEED, MAX_FORWARD_MOTOR_SPEED);
//stop the motors
rotateMotor(0, 0);
void rotateMotor(int rightMotorSpeed, int leftMotorSpeed)
if (rightMotorSpeed < 0)
digitalWrite(rightMotorPin1,LOW);
digitalWrite(rightMotorPin2,HIGH);
else if (rightMotorSpeed > 0)
digitalWrite(rightMotorPin1,HIGH);
digitalWrite(rightMotorPin2,LOW);
if (leftMotorSpeed < 0)
digitalWrite(leftMotorPin1,LOW);
digitalWrite(leftMotorPin2,HIGH);
else if (leftMotorSpeed > 0)
digitalWrite(leftMotorPin1,HIGH);
digitalWrite(leftMotorPin2,LOW);
analogWrite(enableRightMotor, abs(rightMotorSpeed));
analogWrite(enableLeftMotor, abs(leftMotorSpeed));
