Like an external clock
like an RTC ?
Yeh
The ones I know don't give microsecond information...
if your loop content is only a few hundred nano-seconds, you need something that has better granularity than what you measure and is fast to access.
➜ so the question is what do you expect the loop to do and how long (ballpark) that would take?
It really depends but interrupts could be used, right?
Ideally you want a counter (timer) which does not need any interruption otherwise you start impacting what you are trying to measure
Yeah. I don't actually need any code to run that fast at this point, but its probably good practice to try to make it as fast as possible
It just needs to be fast enough for the requirements ![]()
(Over engineering a solution might be costly)
No. Reading a 32bit microsecond count over a pin would typically be MUCH slower than the current micros() function...
Look, your test code demonstrates that micros() is much slower than millis(), but that's been explained: millis() is a very simple function that doesn't do much, so it is VERY fast. micros() does more work - it combines two separate counters (millisecond interrupts and individual timer ticks) with some moderate math. Easily several times more complicated, and millis() may get in-lined as well.
But that doesn't mean that micros() is actually SLOW! Here's the object code generated for micros() on an Uno:
unsigned long micros() {
unsigned long m;
uint8_t oldSREG = SREG, t;
3da: 3f b7 in r19, 0x3f ; 63
cli();
3dc: f8 94 cli
m = timer0_overflow_count;
3de: 80 91 ad 01 lds r24, 0x01AD
3e2: 90 91 ae 01 lds r25, 0x01AE
3e6: a0 91 af 01 lds r26, 0x01AF
3ea: b0 91 b0 01 lds r27, 0x01B0 ;timer0_overflow_count
t = TCNT0;
3ee: 26 b5 in r18, 0x26 ; 38
if ((TIFR0 & _BV(TOV0)) && (t < 255))
3f0: a8 9b sbis 0x15, 0 ; 21
3f2: 05 c0 rjmp .+10 ; 0x3fe <micros+0x24>
3f4: 2f 3f cpi r18, 0xFF ; 255
3f6: 19 f0 breq .+6 ; 0x3fe <micros+0x24>
m++;
3f8: 01 96 adiw r24, 0x01 ; 1
3fa: a1 1d adc r26, r1
3fc: b1 1d adc r27, r1
SREG = oldSREG;
3fe: 3f bf out 0x3f, r19 ; 63
return ((m << 8) + t) * (64 / clockCyclesPerMicrosecond());
400: ba 2f mov r27, r26
402: a9 2f mov r26, r25
404: 98 2f mov r25, r24
406: 88 27 eor r24, r24
408: bc 01 movw r22, r24
40a: cd 01 movw r24, r26
40c: 62 0f add r22, r18
40e: 71 1d adc r23, r1
410: 81 1d adc r24, r1
412: 91 1d adc r25, r1
414: 42 e0 ldi r20, 0x02 ; 2
416: 66 0f add r22, r22
418: 77 1f adc r23, r23
41a: 88 1f adc r24, r24
41c: 99 1f adc r25, r25
41e: 4a 95 dec r20
420: d1 f7 brne .-12
422: 08 95 ret
(and yes, if you're going to be this nit-picky about the speed of code, you DO need to learn how to interpret the object code!)
I count about 50 cycles for the whole thing; about 3 microseconds execution time. Reading 32bits via a pin would take at least 128 cycles (read a bit, merge into count, loop, times 32...), and that doesn't include clocking or waiting for a slower serial protocol (I2C, used by many clocks, runs at ~400kHz, so that would be 80 microseconds (1280 cycles) just waiting for the bits to arrive.)
