int mode = 0; // Stores the active mode
const int button1 = 3; // Mode 1
const int button2 = 5; // Mode 2
const int button3 = 7; // Mode 3
const int button4 = 9; // Mode 4
const int unitsPins[4] = {24, 25, 26, 27}; // Tens digit (left display)
const int tensPins[4] = {28, 29, 30, 31}; // Units digit (right display)
pinMode(24, OUTPUT);
pinMode(25, OUTPUT);
pinMode(26, OUTPUT);
pinMode(27, OUTPUT);
pinMode(28, OUTPUT);
pinMode(29, OUTPUT);
pinMode(30, OUTPUT);
pinMode(31, OUTPUT);
pinMode(button1, INPUT_PULLUP);
pinMode(button2, INPUT_PULLUP);
pinMode(button3, INPUT_PULLUP);
pinMode(button4, INPUT_PULLUP);
// Function to detect the last activated button and set the mode
void getMode() {
if (debounceButton(button1)) { mode = 1; }
else if (debounceButton(button2)) { mode = 2; }
else if (debounceButton(button3)) { mode = 3; }
else if (debounceButton(button4)) { mode = 4; }
// Function for Mode 1
void mode1Function() {
while (mode == 1) {
// Insert code for Mode 1 here (e.g., LED blink, counter, etc.)
for (int num = 0; num <= 99; num++) {
int tens = num / 10;
int units = num % 10;
for (int i = 0; i < 4; i++) {
digitalWrite(tensPins[i], (tens >> i) & 1);
digitalWrite(unitsPins[i], (units >> i) & 1);
delayCheck(500);
// Function for Mode 2
void mode2Function() {
while (mode == 2) {
for (int j = 9; j >= 0; j--) { // Tens place
digitalWrite(28, (j >> 0) & 1);
digitalWrite(29, (j >> 1) & 1);
digitalWrite(30, (j >> 2) & 1);
digitalWrite(31, (j >> 3) & 1);
for (int m = 9; m >= 0; m--) { // Ones place
digitalWrite(24, (m >> 0) & 1);
digitalWrite(25, (m >> 1) & 1);
digitalWrite(26, (m >> 2) & 1);
digitalWrite(27, (m >> 3) & 1);
delayCheck(500);
// Function for Mode 3
void mode3Function() {
while (mode == 3) {
// Insert code for Mode 3 here
for(int r = 24; r <=31; r++){
//getMode();
for (int i = 24; i <=31; i++){
delayCheck(1);
digitalWrite(i, LOW);
digitalWrite(r, HIGH);
delayCheck(50);
digitalWrite(r, LOW);
// Function for Mode 4
void mode4Function() {
while (mode == 4) {
// Insert code for Mode 4 here
getMode();
delayCheck(1);
void delayCheck(int m){
for(int d = 0; d < m; d++){ if (digitalRead(button1) == LOW) { mode = 1; return; }
if (digitalRead(button2) == LOW) { mode = 2; return; }
if (digitalRead(button3) == LOW) { mode = 3; return; }
if (digitalRead(button4) == LOW) { mode = 4; return; }
delay(1);
}void clearDisplay() {
for (int i = 24; i <= 31; i++) {
}int debounceButton(int pin) {
if (digitalRead(pin) == LOW) {
for (int i = 0; i < 50; i++) { // 50ms debounce delay
delay(1);
if (digitalRead(pin) == HIGH) return 0; // If released early, ignore
while (digitalRead(pin) == LOW); // Wait for full release
return 1; // Valid press detected
return 0;
getMode(); // Check the initial button press
if (mode == 1) mode1Function();
if (mode == 2) mode2Function();
if (mode == 3) mode3Function();
if (mode == 4) mode4Function();
I don't know how to debug my program because looks the same ay my previous codes, just the conditions in each "modes" were different.
