why is my class not known in this scope?
I broke down my more complex code down to this:
struct Actor{
  int x;
void act(Actor t){
and I get the following error:
sketch_dec05a:19:10: error: variable or field 'act' declared void
 void act(Actor t){
sketch_dec05a:19:10: error: 'Actor' was not declared in this scope
exit status 1
Why? It’s literally declared right above “act”. Running the same code in a c++ compiler doesn’t produce this error.
It due to the annoying (IMO) auto-prototype generator in the Arduino IDE. Simplest solution is to more the struct definition to the top above setup() and loop().
You could also do something that looks brain-dead but works because you're supplying the prototype:
struct Actor{
  int x;
void act(Actor t);
void act(Actor t){
gfvalvo:
struct Actor{
 int x;
void act(Actor t);
void act(Actor t){
Thank you, it works!
