Why is My Function Not Working?
Hi everyone, I am new to Arduino and don't understand why my code is giving me an error. I have a simple algorithm to read a thermistor from a voltage divider. I first verified that the code works on its own, then I made it into a function kept within the same .ino file and now I want it to be a separate file. I saved the function as a .cpp file and I made a .h file based off what I saw here:
here is my .ino file:
#include "readTherm.h"
// which analog pin to connect
float THERMISTORPIN = A3;
// the value of the 'other' resistor
float SERIESRESISTOR = 1100;
// "A" variable from S-H Equation
void setup(void) {
  analogReference(EXTERNAL);
void loop(void) {
  float T1;
  T1 = readTherm(THERMISTORPIN, SERIESRESISTOR);
  Serial.print("T1 ");
  Serial.print(T1);
  Serial.println(" *C");
here is my .h file:
#ifndef readTherm_h
#define readTherm_h
readTherm();
#endif
and lastly here is my .cpp file:
float readTherm(float pin, float Rseries) {
  // how many samples to take and average, more takes longer but is more 'smooth'
  int NUMSAMPLES = 5;
  float A = 1.471021608E-3;
  // "B" variable from S-H Equation
  float B = 2.376674669E-4;
  // "C" variable from S-H Equation
  float C = 1.050016627E-7;
  int samples[NUMSAMPLES];
  uint8_t i;
  float average;
  // take N samples in a row, with a slight delay
  for (i=0; i< NUMSAMPLES; i++) {
   samples[i] = analogRead(pin);
   delay(10);
  // average all the samples out
  average = 0;
     average += samples[i];
  average /= NUMSAMPLES;
  Serial.print("Average analog reading ");
  Serial.println(average);
  // convert the value to resistance
  average = 1024 / average - 1;
  average = Rseries / average;
 // average = average + 200; // manual adjustment by me
  Serial.print("Thermistor resistance ");
  float steinhart;
  float D;
  float E;
  float R;
  R = log(average);            // lnR
  D = B * R;                   // B * R
  E = C * R * R * R;           // C * R^3
  steinhart = A + D + E;       // Final S-H Equation
  steinhart = 1.0 / steinhart;                 // Invert
  steinhart -= 273.15;         // convert absolute temp to C
  //Serial.print("Temperature ");
  //Serial.print(steinhart);
  //Serial.println(" *C");
  return steinhart;
The error I am getting says:
"exit status 1
Compilation error: 'readTherm' was not declared in this scope"
I assume there's something wrong with my header file, but as I have never made one before I have no clue what I am doing. Any and all help is greatly appreciated.
I chose a float because I am using the analog pins so I need a letter and number. If you have any better ideas please send them my way. What is wrong with using a float there?
I did that and now a different error came up: "Compilation error: exit status 1"
In case it helps, here is the full error log:
P:\Daniel Sollima\Arduino\TempSense\readTherm.cpp: In function 'float readTherm(float, float)':
P:\Daniel Sollima\Arduino\TempSense\readTherm.cpp:13:3: error: 'uint8_t' was not declared in this scope
   uint8_t i;
P:\Daniel Sollima\Arduino\TempSense\readTherm.cpp:17:8: error: 'i' was not declared in this scope
P:\Daniel Sollima\Arduino\TempSense\readTherm.cpp:18:17: error: 'analogRead' was not declared in this scope
P:\Daniel Sollima\Arduino\TempSense\readTherm.cpp:19:4: error: 'delay' was not declared in this scope
    delay(10);
P:\Daniel Sollima\Arduino\TempSense\readTherm.cpp:19:4: note: suggested alternative: 'decltype'
    delay(10);
    decltype
P:\Daniel Sollima\Arduino\TempSense\readTherm.cpp:24:8: error: 'i' was not declared in this scope
P:\Daniel Sollima\Arduino\TempSense\readTherm.cpp:29:3: error: 'Serial' was not declared in this scope
P:\Daniel Sollima\Arduino\TempSense\readTherm.cpp:43:7: error: 'log' was not declared in this scope
P:\Daniel Sollima\Arduino\TempSense\readTherm.cpp:43:7: note: suggested alternative: 'long'
       long
exit status 1
I added #include <arduino.h> and it still has the same error
That doesn't make it a float!!! Check out the definition of A3 in pins_arduino.h (assuming an Uno):
#define PIN_A3   (17)
static const uint8_t A3 = PIN_A3;
Same error comes up with arrows, quotes, or not even having the #include line
BTW, for a basic guide on that topic, see My Post #5 in this Thread
.ino file (nothing has changed from the original post)
void setup(void) {
void loop(void) {
  float T1;
  Serial.print(T1);
.h file (I added the #include part)
#ifndef readTherm_h
#define readTherm_h
#include "arduino.h"
float readTherm(float, float);
#endif
.cpp file (nothing has changed here)
  int NUMSAMPLES = 5;
  uint8_t i;
  float average;
   delay(10);
  average = 0;
  float steinhart;
  float D;
  float E;
  float R;
  D = B * R;                   // B * R
  return steinhart;
Error Log
   uint8_t i;
    delay(10);
    delay(10);
    decltype
       long
exit status 1
I am currently using an UNO but I will need to used a MEGA later because I will need more inputs.
AHA! I GOT IT! Thank you @gfvalvo it was your post you linked that gave me the solution. I didn't have the #include "readTherm.h" in my .cpp file.
Thank you @Delta_G for trying so hard to help me. I will change my pin number from a float to an int. If there are any other silly mistakes like that in which you can see please tell me. I am brand brand new to Arduino and there is a lot to learn
Please fix the incorrect function arguments. As you already advised, you don't need a floats
