I’ve done something wrong and screwed up the speed at which the homing function operates. It just crawls, yet I set it to the same speed as main movement, which is much quicker.
[code]
// Start #1 for parsing serial
const byte numChars = 32;
char receivedChars[numChars];
char tempChars[numChars]; // temporary array for use when parsing
// variables to hold the parsed data
float XCoordinate = 0;
float YCoordinate = 0;
float ZCoordinate = 0;
float R, S, T;
float AngleThetaOne;
float AngleThetaTwo;
float AngleThetaThree;
char messageFromPC[numChars] = {0};
int StepsPerDegreeOne = 88; //calibrate steps per degree of Theta One
int StepsPerDegreeTwo = 88; // calibrate steps per degree for Theta Two
int StepsPerDegreeThree = 88; // calibrate steps per degree for Theta Three
float J1position = 0;
float J2position = 0;
float J3position = 0;
int J1move = 0;
int J2move = 0;
int J3move = 0;
int X = 0;
int Y = 0;
int Z = 0;
float J1newPosition = 0;
float J2newPosition = 0;
float J3newPosition = 0;
int F = 0, f;
float Q1, W1, E1;
float Q0, Q4, W0, W4, E2;
float Q3, W3, E3;
boolean newData = false;
// end #1
// MultiStepper.pde
// -*- mode: C++ -*-
// Use MultiStepper class to manage multiple steppers and make them all move to
// the same position at the same time for linear 2d (or 3d) motion.
#include <AccelStepper.h>
#include <MultiStepper.h>
// EG X-Y position bed driven by 2 steppers
// Alas its not possible to build an array of these with different pins for each :-(
AccelStepper J1axis(1, A0, A1);
AccelStepper J2axis(1, A6, A7);
AccelStepper J3axis(1, 46, 48);
// Up to 10 steppers can be handled as a group by MultiStepper
MultiStepper steppers;
// Define the Pins used
// limit switches
// J1/x limit min on ramps 1.4
const int J1calPin = 3;
// J2/y limit min on ramps 1.4
const int J2calPin = 14;
// J3/z limit min on rmaps 1.4
const int J3calPin = 18;
// Stepper Travel Variables
int J1move_finished = 1; // Used to check if move is completed
long J1initial_homing = -1; // Used to Home Stepper at startup
int J2move_finished = 1; // Used to check if move is completed
long J2initial_homing = -1; // Used to Home Stepper at startup
int J3move_finished = 1; // Used to check if move is completed
long J3initial_homing = -1; // Used to Home Stepper at startup
// my addition to set x,y, z enable pins to output
pinMode (38, OUTPUT); // x enable pin
pinMode (56, OUTPUT); // y enable pin
pinMode (62, OUTPUT); // z enable pin
digitalWrite (38, LOW); // x enable
digitalWrite (56, LOW); // y enable
digitalWrite (62, LOW); // z enable
pinMode(J1calPin, INPUT_PULLUP);
pinMode(J2calPin, INPUT_PULLUP);
pinMode(J3calPin, INPUT_PULLUP);
// end of my addition
// Configure each stepper
J1axis.setMaxSpeed(3000);
J2axis.setMaxSpeed(3000);
J3axis.setMaxSpeed(3000);
J1axis.setCurrentPosition(0);
J2axis.setCurrentPosition(0);
J3axis.setCurrentPosition(0);
// Then give them to MultiStepper to manage
steppers.addStepper(J1axis);
steppers.addStepper(J2axis);
steppers.addStepper(J3axis);
// Set Max Speed and Acceleration of each Steppers at startup for homing
J1axis.setMaxSpeed(3000.0); // Set Max Speed of Stepper (Slower to get better accuracy)
J1axis.setAcceleration(3000.0); // Set Acceleration of Stepper
J2axis.setMaxSpeed(3000.0); // Set Max Speed of Stepper (Slower to get better accuracy)
J2axis.setAcceleration(3000.0); // Set Acceleration of Stepper
J3axis.setMaxSpeed(3000.0); // Set Max Speed of Stepper (Slower to get better accuracy)
J3axis.setAcceleration(3000.0); // Set Acceleration of Stepper
// Start Homing procedure of Stepper Motor at startup
Serial.println("Stepper is Homing . . . . . . . . . . . ");
while (digitalRead(J1calPin)) { // Make the Stepper move CCW until the switch is activated
J1axis.moveTo(J1initial_homing); // Set the position to move to
J1initial_homing++; // increase by 1 for next move if needed
J1axis.run(); // Start moving the stepper
delay(5);
J1axis.setCurrentPosition(0); // Set the current position as zero for now
J1initial_homing = 1;
while (!digitalRead(J1calPin)) { // Make the Stepper move CW until the switch is deactivated
J1axis.run();
J1initial_homing--;
delay(5);
Serial.print("J1 Homing Completed ");
J1axis.setMaxSpeed(3000.0); // Set Max Speed of Stepper (Faster for regular movements)
//J2 homing
while (digitalRead(J2calPin)) { // Make the Stepper move CCW until the switch is activated
J2axis.moveTo(J2initial_homing); // Set the position to move to
J2initial_homing--; // Decrease by 1 for next move if needed
J2axis.run(); // Start moving the stepper
delay(5);
J2axis.setCurrentPosition(0); // Set the current position as zero for now
J2initial_homing = 1;
while (!digitalRead(J2calPin)) { // Make the Stepper move CW until the switch is deactivated
J2axis.run();
J2initial_homing++;
delay(5);
Serial.print("J2 Homing Completed ");
J2axis.setMaxSpeed(3000.0); // Set Max Speed of Stepper (Faster for regular movements)
// J3 homing
while (digitalRead(J3calPin)) { // Make the Stepper move CCW until the switch is activated
J3axis.moveTo(J3initial_homing); // Set the position to move to
J3initial_homing--; // Decrease by 1 for next move if needed
J3axis.run(); // Start moving the stepper
delay(5);
J3axis.setCurrentPosition(0); // Set the current position as zero for now
J3initial_homing = 1;
while (!digitalRead(J3calPin)) { // Make the Stepper move CW until the switch is deactivated
J3axis.run();
J3initial_homing++;
delay(5);
Serial.print("J3 Homing Completed");
J3axis.setMaxSpeed(3000.0); // Set Max Speed of Stepper (Faster for regular movements)
//addition
// after homing, move off home position
J1newPosition = 9680;
J2newPosition = 500;
J3newPosition = 500;
// message for input
Serial.println("Input the Coordinates of X,Y,Z in format of <X,Y,Z>");
// end addition
[/code]
EDIT: I believe I have found the answer. It was the delay (5) at the end of each homing loop.
