Why is my IR sensor taking values non stop even though I pressed the button on remote only once?
Here is code:
Here is circuit:
Here is Serial Monitor:
No, that's a picture of code.
Post actual code.
If there are error messages, post actual error messages.
We can't paste pictures into the IDE.
Most probably you forgot to re-enable the IR receiver.
Please learn how to use the forum for substantial help.
@rahul_pro - When you add code to your topic, click on the < CODE > button, then copy/paste your code where you see '''type or paste code here'''
Your code needs some changes. Compare it to this IRremote sketch... look for this to solve the non-stop issue:
    irrecv.resume();  // Receive the next value
Thank you, I actually did forget in haste to re-enable the IR receiver.
