I have a map and my robot is moving on this map using the PID algorithm. Since I need manual intervention in some turns, I run the system by creating various scenario functions (30 of them). When I start the system from the beginning, my robot starts to turn around after about 20 scenarios. When I start from the middle, it finishes successfully. Apart from this, I tried all the parts with various scenarios. I tried all the scenarios by moving away from the start line and this problem started to occur one scenario ahead each time. What could be the cause of this?
#include <QTRSensors.h>
#define Rpwm1 6
#define RDir1 7
#define RDir2 8
#define Lpwm1 11
#define LDir1 10
#define LDir2 9
#define Buzzer 3
QTRSensors qtr;
const uint8_t SensorCount = 8;
uint16_t sensorValues[SensorCount];
float LeftBaseSpeed = 60 ;
float RightBaseSpeed = 60 ;
float TurnTime=100; //milisaniye
float TurnSpeed=80;
float StraightSpeed=70;
float StraightTime=70;
float CheckTime=300;
float Kp = 0.0275;//0.0275;//0.07
float Kd =0.15 ;//0.3 ;//0.275;// 0.1 ; // 2
float Ki =0.0001; //0.0001;// 0.0001 ; //0.0001
int FinalError = 0;
int Error = 0;
int ExtraSpeed = 0;
int RightSpeed = 0;
int LeftSpeed = 0;
int Integral = 0;
int Val = 0;
int donus=22;
int senaryo=22;
int baslangicZamani=0;
unsigned int Position = 3500;
byte WhiteLine = 0;
// configure the sensors
qtr.setTypeAnalog();
qtr.setSensorPins((const uint8_t[]){A0, A1, A2, A3, A4, A5,A6,A7}, SensorCount);
qtr.setEmitterPin(2);
pinMode(Rpwm1, OUTPUT);
pinMode(Lpwm1, OUTPUT);
pinMode(RDir1, OUTPUT);
pinMode(RDir2, OUTPUT);
pinMode(LDir1, OUTPUT);
pinMode(LDir2, OUTPUT);
pinMode(Buzzer, OUTPUT);
// pinMode(LED1, OUTPUT);
// pinMode(LED2, OUTPUT);
// pinMode(MZ80, INPUT_PULLUP);
// pinMode(startbuton, INPUT_PULLUP);
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH); // turn on Arduino's LED to indicate we are in calibration mode
// Serial.begin(9600);
for (uint16_t i = 0; i < 200; i++)
qtr.calibrate();
digitalWrite(LED_BUILTIN, LOW);
Blink();// turn off Arduino's LED to indicate we are through with calibration
switch(senaryo)
case 0:Senaryo0();break;
case 1:Senaryo1();break;
case 2:Senaryo2();break;
case 3:Senaryo3();break;
case 4:Senaryo4();break;
case 5:Senaryo5();break;
case 6:Senaryo6();break;
case 7:Senaryo7();break;
case 8:Senaryo8();break;
case 9:Senaryo9();break;
case 10:Senaryo10();break;
case 11:Senaryo11();break;
case 12:Senaryo12();break;
case 13:Senaryo13();break;
case 14:Senaryo14();break;
case 15:Senaryo15();break;
case 16:Senaryo16();break;
case 17:Senaryo17();break;
case 18:Senaryo18();break;
case 19:Senaryo19();break;
case 20:Senaryo20();break;
case 21:Senaryo21();break;
case 22:Senaryo22();break;
case 23:Senaryo23();break;
case 24:Senaryo24();break;
case 25:Senaryo25();break;
case 26:Senaryo26();break;
case 27:Senaryo27();break;
case 28:Senaryo28();break;
case 29:Senaryo29();break;
case 30:Senaryo30();break;
case 31:Senaryo31();break;
case 32:Senaryo32();break;
default:MotorsSpeed(0,0);break;
// WriteSensorValues();
void Senaryo0()
ReadLine();
CheckStraight();
if(donus==1)
senaryo=1;
void Senaryo1()
ReadLine();
CheckRightTurn(CheckTime);
if(donus==2)
senaryo=2;
void Senaryo2()
ReadLine();
CheckLeftTurn(CheckTime);
if(donus==3)
senaryo=3;
void Senaryo3()
ReadLine();
if(donus==4)
senaryo=4;
void Senaryo4()
ReadLine();
if(donus==5)
senaryo=5;
void Senaryo5()
ReadLine();
if(donus==6)
senaryo=6;
void Senaryo6()
ReadLine();
if(donus==7)
senaryo=7;
void Senaryo7()
ReadLine();
CheckRight90Turn(CheckTime);
if(donus==8)
senaryo=8;
void Senaryo8()
ReadLine();
if(donus==9)
RightTurn(TurnSpeed,TurnTime);
senaryo=9;
void Senaryo9()
ReadLine();
// CheckRightTurn();
if(donus==10)
//RightTurn(TurnSpeed,TurnTime);
//LeftTurn(TurnSpeed,TurnTime);
senaryo=10;
void Senaryo10()
ReadLine();
if(donus==11)
// RightTurn(TurnSpeed,TurnTime);
//LeftTurn(TurnSpeed+20,TurnTime);
senaryo=11;
void Senaryo11()
ReadLine();
if(donus==12)
// RightTurn(TurnSpeed);
LeftTurn(TurnSpeed,TurnTime+75);
senaryo=12;
void Senaryo12()
ReadLine();
if(donus==13)
LeftTurn(TurnSpeed,TurnTime+90);
senaryo=13;
void Senaryo13()
ReadLine();
GoStraight(StraightSpeed,StraightTime);
if(donus==14)
senaryo=14;
void Senaryo14()
ReadLine();
if(donus==15)
senaryo=15;
void Senaryo15()
ReadLine();
if(donus==16)
senaryo=16;
void Senaryo16()
ReadLine();
if(donus==17)
senaryo=17;
void Senaryo17()
ReadLine();
if(donus==18)
senaryo=18;
void Senaryo18()
ReadLine();
if(donus==19)
senaryo=19;
void Senaryo19()
ReadLine();
if(donus==20)
GoStraight(70,400);
senaryo=20;
WhiteLine=1;
void Senaryo20()
ReadLine();
CheckBlackLine();
if(donus==21)
senaryo=21;
void Senaryo21()
ReadLine();
CheckLeft90Turn(CheckTime);
if(donus==22)
senaryo=22;
void Senaryo22()
ReadLine();
if(donus==23)
//LeftTurn(TurnSpeed,TurnTime+100);
senaryo=23;
void Senaryo23()
ReadLine();
if(donus==24)
senaryo=24;
void Senaryo24()
ReadLine();
if(donus==25)
senaryo=25;
void Senaryo25()
ReadLine();
if(donus==26)
RightTurn(TurnSpeed,TurnTime+100);
senaryo=26;
void Senaryo26()
ReadLine();
if(donus==27)
senaryo=27;
// BEŞGENİN OLDUĞU YER
void Senaryo27()
ReadLine();
if(donus==28)
senaryo=28;
void Senaryo28()
ReadLine();
if(donus==29)
//RightTurn(TurnSpeed,TurnTime+200);
senaryo=29;
void Senaryo29()
ReadLine();
if(donus==30)
senaryo=30;
void Senaryo30()
ReadLine();
if(donus==31)
senaryo=31;
void Senaryo31()
ReadLine();
if(donus==32)
senaryo=32;
void Senaryo32()
ReadLine();
CheckStraight();
if(donus==33)
while(true)
MotorsSpeed(0,0);
senaryo=33;
void GoStraight(int speed,int time)
do
MotorsSpeed(speed,speed);
}while(baslangicZamani+time>millis());
void WriteSensorValues()
uint16_t position;
if(WhiteLine==1)
position = qtr.readLineWhite(sensorValues);
position = qtr.readLineBlack(sensorValues);
for (uint8_t i = 0; i < SensorCount; i++)
Serial.print(sensorValues[i]);
Serial.print('\t');
Serial.println(position);
delay(250);
void ReadLine()
if(WhiteLine==1)
Position = qtr.readLineWhite(sensorValues);
Position = qtr.readLineBlack(sensorValues);
Error = Position - 3500;
Integral += Error;
// Integral = constrain(Integral, INTEGRAL_MIN, INTEGRAL_MAX);
int Verify = Kp * Error + Kd * (Error - FinalError) + Ki * Integral;
FinalError = Error;
RightSpeed = RightBaseSpeed + Verify + ExtraSpeed ;
LeftSpeed = LeftBaseSpeed - Verify + ExtraSpeed ;
RightSpeed = constrain(RightSpeed, -250, 250);
LeftSpeed = constrain(LeftSpeed, -250, 250);
MotorsSpeed(LeftSpeed, RightSpeed);
void MotorsSpeed(int RightSpeed, int LeftSpeed) {
if (RightSpeed <= 0) {
RightSpeed = abs(RightSpeed);
analogWrite(Rpwm1, RightSpeed);
digitalWrite(RDir1, HIGH);
digitalWrite(RDir2, LOW);
else {
digitalWrite(RDir1, LOW);
digitalWrite(RDir2, HIGH);
if (LeftSpeed <= 0) {
LeftSpeed = abs(LeftSpeed);
analogWrite(Lpwm1, LeftSpeed);
digitalWrite(LDir1, HIGH);
digitalWrite(LDir2, LOW);
else {
digitalWrite(LDir1, LOW);
digitalWrite(LDir2, HIGH);
void CheckBlackLine()
if(sensorValues[0]<200 &&sensorValues[1] <200 &&sensorValues[2]<200&&sensorValues[3]>700&& sensorValues[4]>700 &&sensorValues[5]<200 &&sensorValues[6]<200&&sensorValues[7]<200)
WhiteLine=0;
donus++;
void CheckRightTurn(float checkTime)
if(sensorValues[1]>900 &&( (millis()- baslangicZamani) >=checkTime ) )
baslangicZamani=millis();
donus++;
void CheckRight90Turn(float checkTime)
if(sensorValues[1]>900&& sensorValues[0]>900 &&( (millis()- baslangicZamani) >=checkTime ) )
donus++;
void CheckLeft90Turn(float checkTime)
if(sensorValues[7]>900&& sensorValues[6]>900 &&( (millis()- baslangicZamani) >=checkTime ) )
donus++;
void CheckLeftTurn(float checkTime)
if(sensorValues[6]>900 &&( (millis()- baslangicZamani) >=checkTime ))
donus++;
void RightTurn(int turnSpeed,int turnTime)
int startTime=millis();
do
MotorsSpeed(turnSpeed,-turnSpeed);
}while(startTime+turnTime>millis());
void LeftTurn(int turnSpeed,int turnTime)
do
MotorsSpeed(-turnSpeed,turnSpeed);
void CheckStraight()
int baslangicZamani=millis();
if(sensorValues[0]>700 &&sensorValues[1] >700 &&sensorValues[2]>700&&sensorValues[3]>700&& sensorValues[4]>700 &&sensorValues[5] >700 &&sensorValues[6]>700&&sensorValues[7]>700)
do
MotorsSpeed(150,150);
}while(baslangicZamani+100>millis());
donus++;
void Stop()
while(true)
MotorsSpeed(0,0);
void Blink() {
for (int i = 0; i < 10; i++) {
// digitalWrite(Led, LOW);
digitalWrite(Buzzer, LOW);
delay(180);
// digitalWrite(Led, HIGH);
digitalWrite(Buzzer, HIGH);
delay(180);
