Why is my looped code not repeating in the loop function?
This is a relatively simple program that I have to complete for a class, and I need to use a function to control the color of the led's to simulate a "traffic light." However, the function just isn't starting again. I have tried using return after the while loop, as well as setting a 4th case turn off all the lights, but nothing works.
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
void trafficLight (int color)  {
  switch (color) {
    case 1:
      digitalWrite(8,HIGH);
      digitalWrite(10,LOW);
      digitalWrite(9,LOW);
    case 2:
      digitalWrite(9,HIGH);
      digitalWrite(8,LOW);
    case 3:
      digitalWrite(10,HIGH);
      case 4:
    return;
 int times = millis();
int i=1;
      /*if (times < 2000) {
        trafficLight(1);
      else if (2000 <= times <= 5000){
        trafficLight(2);
      else if (times <= 10000) {
        trafficLight(3);
      while (times <6500){
        trafficLight(i);
        i++;
        delay(2000);
    return;
This is because once the processor has been running for over six seconds this code never runs again.
Try
      while ( millis()-times <6500){
P.S. and you must use unsigned long as the type for times
Non-blocking timing tutorials:
Blink without delay().
Beginner's guide to millis().
Several things at a time.
