Hello, in the past few weeks I've been working on a project about measuring the wind speed using the sensor MPX10DP and the amplifier INA125 (pieces given by my teacher to make this project possible) however I've been strugling with the measure of pressure necessary for the wind speed formula. This pressure is always negative and I dont know why. I calibrated the sensor from 0 to 1 kPa (I know it isn't the proper equipment but it's what i have) and I think it has something to do with this. Also when amplifying the signal i notice somthing odd, i get diferent values for the same experiment as you can see in the images below.
int value=analogRead(A0);
float Vout=value*4.9; //Voltage in mV
float Pressao=0.2142*(Vout/57.097) - 5.7304; //after calibration
float root=2*Pressure*1000/1.225;
float Velocidade=((float)sqrt(raiz)*3600/1000);
Serial.println(Pressao*1000);//i only print the pressure in Pa because if its positive i will have some velocity
delay(100);
The results below are both for the Rg of 1kohm
Btw to make it clear what i'm asking is for guidance in what to do next due to this results i'm having.
Thx for your time
There could be something wrong with your amplifier circuit, or it could be your formula/algorithm.
You might look (print-out) at the raw readings (either "value" or "Vout") to see if they are correct at known pressures. And/or, you can check the voltage with a multimeter. If you have a multimeter that's sensitive enough, check the unamplified voltage out of the sensor.
If those readings are bad you've got a hardware/amplifier problem and if they are correct you've got a software problem
Some things to check
What you should calibrate ... the raw A0 value or pressure value?
What happens to your numbers as you go from the raw A0 value to your final printed result
What happens to your final resolution ... each chart shows about 20 Pa? per step
Some things to consider
What is the Min and Max values you'll ever need to work with?
Do you need to contstrain, scale or shift readings prior to calibration?
Something to try
Use a for loop to cycle through all possible values to see what results you get.
Thanks for all the awnsers. A few things:
I am trying to measure the air speed by a pitot tube (in this case a prundtl tube)
The ADC value on both of my exits of the sensor are 3.5mV (positive) and 3.2/3.3mV(negative) wich is okay (i cant measure more accurate because my multimeter cant read more)
When i calibrate the pressure sensor i do it by using water coluns of around 0 to 5 cm (i know again ins't the rigth sensor for this porpose) that means i get pressure from 0.05 Pa to 0.25 Pa, however because of the linearity of the equation i can calculate speed up to 60km/h (37.28mph).
You said you were amplifying the sensor signal with an INA125 with a Rg of 1K, an amplification factor of 64. The sensor datasheet says, with zero pressure the offset voltage is about 20mV, 0.02 * 64 = 1.28V. So, with zero pressure on both sensor ports, what is the INA125 output voltage?
BTW: A 5cm water column is 490Pa, 0.49kPa.
