Why is my the output on my serial monitor questionmarks?
i modified the part 3 of the code Using millis() for timing. A beginners guide. But the output on my serial monitor is like this:
Press button as many times as possible in 5 seconds
7⸮ ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮
everytime i press the button, the question mark adds and adds.
unsigned long startMillis;
unsigned long currentMillis;
const unsigned long period = 5000;  //period during which button input  is valid
const byte buttonPin1 = A1;    //button on pin A1
byte currentButtonState;
byte previousButtonState;
int count = 0;
boolean counting;
  pinMode(buttonPin1, INPUT_PULLUP);
  Serial.println("Press the button as many times as possible in 5 seconds");
  counting = true;    //turn on the counting indicator
  startMillis = millis();  //save the start time
  currentMillis = millis();
  previousButtonState = currentButtonState;
  if (currentMillis - startMillis <= period)  //true until the period elapses.  Note that this is the reverse of BWOD
    currentButtonState = digitalRead(buttonPin1);
    if (currentButtonState == LOW and previousButtonState == HIGH)  //the button has become pressed
      count++;    //increment count
      Serial.println(count);
  else  //period has ended
    if (counting == true)  //if we were counting
      Serial.print("Time is up");
      counting = false;    //prevent the message being displayed again
Make sure your Serial monitor baud rate matches your Serial.begin() line (115200).
How is your button wired, between pin and GND or pin and5V?
outsider:
lol i didnt set the baud rate to 115200. thanks
