Why is my validation not working anymore?
So I have a simple sketch here where I enter a value via the serial monitor and validate the entry with an If statement, but for some reason it's not working even though it did this morning. I've added a couple of Serial.printlns just to verify that my String is being populated but the validation fails every time. Am I totally off my rocker here?
String input;
void setup(){
Serial.begin(19200);
void loop(){
if (Serial.available() > 0) {
  input=Serial.readString();
  Serial.println(input);
  if(input == "test"){
    Serial.println("True");
  else{
    Serial.println("False");
Does it help if you try changing the carriage return or new line settings in the serial monitor?
Your code works; the only way I can get it to 'fail' is if I set serial monitor to send CR and/or NL as the line ending.
I feel like an idiot.
Thanks guys.
