why is the var out of scope?
Hi
i have a simple class, but he tells me that _bluePin, _greenPin and _redPin are out of scope(?) in the light.cpp in analogWrite(_bluePin, blue);
light.h
#ifndef light_h
#define light_h
#include "Arduino.h"
class light {
  public:
    light(int redPin, int greenPin, int bluePin);
    void setColor(int red, int green, int blue);
  private:
    int _redPin;
    int _greenPin;
    int _bluePin;
#endif
light.cpp
  light.cpp
#include "light.h"
light::light(int r, int g, int b) {
    _redPin = r;
    _greenPin = g;
    _bluePin = b;
 void setColor(int red, int green, int blue) {
    #ifdef COMMON_ANODE
        red = 255 - red;
        green = 255 - green;
        blue = 255 - blue;
    #endif
    analogWrite(_redPin, red);
    analogWrite(_greenPin, green);
why is that?
Missing scope resolution operator ::
AWOL:
sorry, can you explain?
You defined the pin numbers as private members of the class "light", which means that they are out of scope to anything that is not a member of "light".
The constructor "light::light" (hint) is a member of "light", but "setColor" is not.
Is setColor a method of your class? how do you declare a method (member functions of a class)?
AWOL:
aaaaaaaahh.. so you mean it should be
  void light::setColor(int red, int green, int blue) {
i though so (??) oO ..
class light {
public:
..what do you mean?
Yup - hence the earlier comment about the scope resolution operator.
I meant to help with the hint of AWOL in #1 but was slow to type so more info arrived in between
hey cool :slight_smile: .. big thanks to both :slight_smile:
