I am attempting to set up a mesh network with some NRF24L01 transceivers. I have the following libraries from TMRh20’s github: RF24-master, RF24Mesh-master, RF24Network-master. I was trying to get them to send messages through the network, and I kept getting blank on the serial monitor. After accidentally forgetting to close out the serial monitor after another fail attempt, I noticed it now had values (not sent from one to another).
The logical conclusion was that something made it wait so long for this. I put in some extra commands to read where in the code it takes so long, and it turns out it was in the mesh.begin().
The only thing is this only happened with the one code, so now I am confused.
This is the code where it takes a full minute on the begin mesh()
#include <SPI.h>
#include "RF24.h"
#include "RF24Mesh.h"
#include "RF24Network.h"
RF24 radio (7, 8);
RF24Network network(radio);
RF24Mesh mesh(radio,network);
int data;
radio.begin();
mesh.setNodeID(23);
Serial.println(millis());
//takes 60 seconds to begin mesh
mesh.begin();
data = analogRead(A0);
mesh.update();
uint16_t recipient_address = 00;
RF24NetworkHeader moisture;
network.write(moisture,&data,sizeof(data));
Serial.println(data);
the first value is around 1000 and the second is about 61500
Here is the other code
#include <SPI.h>
#include "RF24.h"
RF24 radio (7, 8);
mesh.setNodeID(0);
Serial.println(mesh.getNodeID());
//takes about a second to begin mesh
mesh.begin();
mesh.setStaticAddress(23, 02);
mesh.setStaticAddress(24, 03);
mesh.setStaticAddress(0, 00);
radio.begin();
mesh.update();
mesh.DHCP();
if (network.available())
{network.peek(moisture);
uint32_t data;
network.read(moisture, &data, sizeof(data));
Serial.println(data);}
else {Serial.println("fail");}
//Serial.println(data.moisture);
// Serial.println((-10.32 * (log(data.moisture) / log(2.718)) + 72.66));
In this one, both values are very near each other, both around 1000.
It seems like they would do the exact same thing, but for some reason the one code takes so much longer. I tried both codes with multiple Arduinos and multiple transceivers, but the first code always took 60 seconds and the second code always was instant.
Any clue as to why this happens? Also if you are good with this code, it would be great if you could point out where the code itself is wrong (as in why it doesn’t send properly).
