Firstly, I just want to thank anyone who is willing to help me with this. I have some knowledge of C++ and arduino but there are still many things I don`t know yet. I hope I am just making a silly mistake. I know these sort of topics can be quite difficult and annoying, so I firstly want to thank anyone willing to support me with this.
I am working on an arduino based 3D scanner (Fabscan 100) project. There is a tutorial page with all the code I am working with from about 10 years ago. My hardware is working with the test code but not responding to the code which I need to actually use for my project. I am wondering if anyone can take a look at the code help me figure out why it isn`t working. Is the code too old and some revisions need to be made or is it something else?
There are three components of the project which are controlled by the code: an LED, a laser, and a motor. The motor has a motor stepper but doesn't include the optional laser stepper. I have also already tried removing the references in the code to the laser stepper but it still doesnt function. When I try to run the code the LED and Laser turn on and the motor does not move. Nothing else happens after that. The motor is supposed to move a bit and then after setup, send the computer a ping and turn the LED off.
Also, I am wondering about the variables defined to number in the 200s in the second link, is this something to do with an official shield? I made my own from a breadboard shield.
Test code:[quote="hyperapeiron, post:1, topic:1068980, full:true"]
I am working on an arduino based 3D scanner (Fabscan 100) project. There is a tutorial page with all the code I am working with from about 10 years ago. My hardware is working with the test code (FabScan100/TestFabScanShieldV11.ino at master · francisengelmann/FabScan100 · GitHub) but not responding to the code (providing the following code to follow: FabScan100/FabScanArduinoFirmware.ino at master · francisengelmann/FabScan100 · GitHub) which I need to actually use for my project. I am wondering if anyone can take a look at the code help me figure out why it isn`t working. Is the code too old and some revisions need to be made or is it something else?
Thank you so much! Any response is greatly appreciated!
Test code:
// FabScan - http://hci.rwth-aachen.de/fabscan
// R. Bohne 30.12.2013
// This sketch tests all four stepper drivers on the FabScan-Shield V1.1
// It also turns on the light and the laser
// This sketch is not the real FabScan firmware, but just a test script for people who want to test their hardware!
// at startup, the sketch blinks all leds, the light and the motor a few times and after that, it starts to spin the motors.
#define LIGHT_PIN 17
#define LASER_PIN 18
#define MS_PIN 19
//Stepper 1 as labeled on Shield, Turntable
#define ENABLE_PIN_0 2
#define STEP_PIN_0 3
#define DIR_PIN_0 4
//Stepper 2, Laser Stepper
#define ENABLE_PIN_1 5
#define STEP_PIN_1 6
#define DIR_PIN_1 7
//Stepper 3, currently unused
#define ENABLE_PIN_2 11
#define STEP_PIN_2 12
#define DIR_PIN_2 13
//Stepper 4, currently unused
#define ENABLE_PIN_3 14
#define STEP_PIN_3 15
#define DIR_PIN_3 16
pinMode(LASER_PIN, OUTPUT);
pinMode(LIGHT_PIN, OUTPUT);
pinMode(MS_PIN, OUTPUT);
digitalWrite(MS_PIN, HIGH); //HIGH for 16microstepping, LOW for no microstepping
pinMode(ENABLE_PIN_0, OUTPUT);
pinMode(DIR_PIN_0, OUTPUT);
pinMode(STEP_PIN_0, OUTPUT);
pinMode(ENABLE_PIN_1, OUTPUT);
pinMode(DIR_PIN_1, OUTPUT);
pinMode(STEP_PIN_1, OUTPUT);
pinMode(ENABLE_PIN_2, OUTPUT);
pinMode(DIR_PIN_2, OUTPUT);
pinMode(STEP_PIN_2, OUTPUT);
pinMode(ENABLE_PIN_3, OUTPUT);
pinMode(DIR_PIN_3, OUTPUT);
pinMode(STEP_PIN_3, OUTPUT);
//enable turntable and laser steppers
digitalWrite(ENABLE_PIN_0, LOW); //HIGH to turn off
digitalWrite(ENABLE_PIN_1, LOW); //HIGH to turn off
digitalWrite(ENABLE_PIN_2, LOW); //LOW to turn on
digitalWrite(ENABLE_PIN_3, LOW); //LOW to turn on
//blink all leds, lights ans the laser 10 times
for(int i=0; i<10; i++)
digitalWrite(ENABLE_PIN_0, HIGH); //HIGH to turn off
digitalWrite(ENABLE_PIN_1, HIGH); //HIGH to turn off
digitalWrite(ENABLE_PIN_2, HIGH); //LOW to turn on
digitalWrite(ENABLE_PIN_3, HIGH); //LOW to turn on
digitalWrite(LIGHT_PIN, 0); //turn light off
digitalWrite(LASER_PIN, 0); //turn laser off
delay(120);
digitalWrite(LIGHT_PIN, 1); //turn light on
digitalWrite(LASER_PIN, 1); //turn laser on
delay(120);
//loop just steps all four steppers. Attached motors should turn!
digitalWrite(STEP_PIN_0, HIGH);
digitalWrite(STEP_PIN_1, HIGH);
digitalWrite(STEP_PIN_2, HIGH);
digitalWrite(STEP_PIN_3, HIGH);
delay(1);
digitalWrite(STEP_PIN_0, LOW);
digitalWrite(STEP_PIN_1, LOW);
digitalWrite(STEP_PIN_2, LOW);
digitalWrite(STEP_PIN_3, LOW);
delay(1);
Project code:
// Created by Francis Engelmann on 7/1/11.
// Copyright 2011 Media Computing Group, RWTH Aachen University. All rights reserved.
// Chngelog:
// R. Bohne 29.01.2013: changed pin mapping to Watterott FabScan Arduino Shield
// R. Bohne 30.12.2013: added pin definitions for stepper 4 --> this firmware supports the new FabScan Shield V1.1, minor syntax changes. Steppers are now disabled at startup.
// R. Bohne 12.03.2014: renamed the pins 14..19 to A0..A5 (better abstraction for people who use Arduino MEGA, etc.)
#define LIGHT_PIN A3
#define LASER_PIN A4
#define MS_PIN A5
#define DIR_PIN_0 4
#define DIR_PIN_1 7
#define ENABLE_PIN_3 A0
#define STEP_PIN_3 A1
#define DIR_PIN_3 A2
#define TURN_LASER_OFF 200
#define TURN_LASER_ON 201
#define PERFORM_STEP 202
#define SET_DIRECTION_CW 203
#define SET_DIRECTION_CCW 204
#define TURN_STEPPER_ON 205
#define TURN_STEPPER_OFF 206
#define TURN_LIGHT_ON 207
#define TURN_LIGHT_OFF 208
#define ROTATE_LASER 209
#define FABSCAN_PING 210
#define FABSCAN_PONG 211
#define SELECT_STEPPER 212
#define LASER_STEPPER 11
#define TURNTABLE_STEPPER 10
//the protocol: we send one byte to define the action what to do.
//If the action is unary (like turnung off the light) we only need one byte so we are fine.
//If we want to tell the stepper to turn, a second byte is used to specify the number of steps.
//These second bytes are defined here below.
#define ACTION_BYTE 1 //normal byte, first of new action
#define LIGHT_INTENSITY 2
#define TURN_TABLE_STEPS 3
#define LASER1_STEPS 4
#define LASER2_STEPS 5
#define LASER_ROTATION 6
#define STEPPER_ID 7
int incomingByte = 0;
int byteType = 1;
int currStepper;
//current motor: turn a single step
void step()
if(currStepper == TURNTABLE_STEPPER){
}else if(currStepper == LASER_STEPPER){
delay(3);
delay(3);
//step the current motor for <count> times
void step(int count)
for(int i=0; i<count; i++){
step();
// initialize the serial port
//disable all steppers at startup
digitalWrite(LIGHT_PIN, LOW); //turn light off
digitalWrite(LASER_PIN, HIGH); //turn laser on
Serial.write(FABSCAN_PONG); //send a pong back to the computer so we know setup is done and that we are actually dealing with a FabScan
currStepper = TURNTABLE_STEPPER; //turntable is default stepper
if(Serial.available() > 0){
incomingByte = Serial.read();
switch(byteType){
case ACTION_BYTE:
switch(incomingByte){ //this switch always handles the first byte
//Laser
case TURN_LASER_OFF:
digitalWrite(LASER_PIN, LOW); // turn the LASER off
case TURN_LASER_ON:
digitalWrite(LASER_PIN, HIGH); // turn the LASER on
case ROTATE_LASER: //unused
byteType = LASER_ROTATION;
//TurnTable
case PERFORM_STEP:
byteType = TURN_TABLE_STEPS;
case SET_DIRECTION_CW:
digitalWrite(DIR_PIN_0, HIGH);
digitalWrite(DIR_PIN_1, HIGH);
case SET_DIRECTION_CCW:
digitalWrite(DIR_PIN_0, LOW);
digitalWrite(DIR_PIN_1, LOW);
case TURN_STEPPER_ON:
case TURN_STEPPER_OFF:
case TURN_LIGHT_ON:
byteType = LIGHT_INTENSITY;
case TURN_LIGHT_OFF:
case FABSCAN_PING:
delay(1);
case SELECT_STEPPER:
byteType = STEPPER_ID;
case LIGHT_INTENSITY: //after this point we take care of the second byte if one is sent
analogWrite(LIGHT_PIN, incomingByte);
byteType = ACTION_BYTE; //reset byteType
case TURN_TABLE_STEPS:
step(incomingByte);
case STEPPER_ID:
Serial.write(incomingByte);
currStepper = incomingByte;
