I am trying to understand the syntax and convention used by my betters and have been studying the code for a test routine used as a sample in the FaseLED library. The question I have is immediately after the void setup() routine, there is some code not within the setup but prior to the void loop().
The segment in question is this:
// List of patterns to cycle through. Each is defined as a separate function below.
typedef void (*SimplePatternList[])();
SimplePatternList gPatterns = { rainbow, rainbowWithGlitter, confetti, sinelon, juggle, bpm };
uint8_t gCurrentPatternNumber = 0; // Index number of which pattern is current
uint8_t gHue = 0; // rotating "base color" used by many of the patterns
The program runs as expected but I am trying to learn c++ on the Arduino and don't understand why this code is not within the setup routine. My understanding is that the board will execute the setup() everytime it is powered up and that the void loop() is the "body" of the program. My assumption is that the code I mention after the setup is run after the setup routine but before the void loop(). Is this accurate? Is this functionally identical to putting that code within the setup() routine?
I am not trying to nit pick the style of the author but trying to understand if this is done for a reason or just a style issue. Thanks in advance.
FYI am an old school programmer who pursued a medical career and programs infrequently for fun/hobby. I was last employed as a programmer in the early 80's.
Code follows.
#include <FastLED.h>
FASTLED_USING_NAMESPACE
// FastLED "100-lines-of-code" demo reel, showing just a few
// of the kinds of animation patterns you can quickly and easily
// compose using FastLED.
// This example also shows one easy way to define multiple
// animations patterns and have them automatically rotate.
// -Mark Kriegsman, December 2014
#if defined(FASTLED_VERSION) && (FASTLED_VERSION < 3001000)
#warning "Requires FastLED 3.1 or later; check github for latest code."
#endif
#define DATA_PIN 12
//#define CLK_PIN 4
#define LED_TYPE WS2812B
#define COLOR_ORDER GRB
#define NUM_LEDS 16
CRGB leds[NUM_LEDS];
#define BRIGHTNESS 96
#define FRAMES_PER_SECOND 120
delay(3000); // 3 second delay for recovery
// tell FastLED about the LED strip configuration
FastLED.addLeds<LED_TYPE, DATA_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
//FastLED.addLeds<LED_TYPE,DATA_PIN,CLK_PIN,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
// set master brightness control
FastLED.setBrightness(BRIGHTNESS);
// Call the current pattern function once, updating the 'leds' array
gPatterns[gCurrentPatternNumber]();
// send the 'leds' array out to the actual LED strip
FastLED.show();
// insert a delay to keep the framerate modest
FastLED.delay(1000 / FRAMES_PER_SECOND);
// do some periodic updates
EVERY_N_MILLISECONDS( 20 )
gHue++; // slowly cycle the "base color" through the rainbow
EVERY_N_SECONDS( 10 )
nextPattern(); // change patterns periodically
#define ARRAY_SIZE(A) (sizeof(A) / sizeof((A)[0]))
void nextPattern()
// add one to the current pattern number, and wrap around at the end
gCurrentPatternNumber = (gCurrentPatternNumber + 1) % ARRAY_SIZE( gPatterns);
void rainbow()
// FastLED's built-in rainbow generator
fill_rainbow( leds, NUM_LEDS, gHue, 7);
void rainbowWithGlitter()
// built-in FastLED rainbow, plus some random sparkly glitter
rainbow();
addGlitter(80);
void addGlitter( fract8 chanceOfGlitter)
if( random8() < chanceOfGlitter)
leds[ random16(NUM_LEDS) ] += CRGB::White;
void confetti()
// random colored speckles that blink in and fade smoothly
fadeToBlackBy( leds, NUM_LEDS, 10);
int pos = random16(NUM_LEDS);
leds[pos] += CHSV( gHue + random8(64), 200, 255);
void sinelon()
// a colored dot sweeping back and forth, with fading trails
fadeToBlackBy( leds, NUM_LEDS, 20);
int pos = beatsin16(13, 0, NUM_LEDS);
leds[pos] += CHSV( gHue, 255, 192);
void bpm()
// colored stripes pulsing at a defined Beats-Per-Minute (BPM)
uint8_t BeatsPerMinute = 62;
CRGBPalette16 palette = PartyColors_p;
uint8_t beat = beatsin8( BeatsPerMinute, 64, 255);
for( int i = 0; i < NUM_LEDS; i++) //9948
leds[i] = ColorFromPalette(palette, gHue + (i * 2), beat - gHue + (i * 10));
void juggle()
// eight colored dots, weaving in and out of sync with each other
byte dothue = 0;
for( int i = 0; i < 8; i++)
leds[beatsin16(i + 7, 0, NUM_LEDS)] |= CHSV(dothue, 200, 255);
dothue += 32;
