I have the debounce set for a rediculous 8 secs, just for debugging.
Anyways .. you should not be able to push the button any more than
once per every 8 secs.
But the little bugger is getting past it ...
I can push the button every sec and it accepts it ...
HOW ???
const int Request_Button = 4; // this is the open and close button
unsigned long Previous_Time = 0; // the time var's are for timing the opening
unsigned long Current_Time = 0; // and closing making sure it isn't stuck
unsigned long Prev_Button_Time = 0;
bool Button_Was_Pressed = false; // var for button condition
pinMode(Request_Button, INPUT_PULLUP); // pin 4
Check_For_Button();
//Obey_The_Button();
//Check_For_Open_Limit();
//Check_For_Close_Limit();
//Check_For_Stuck_Gate();
void Check_For_Button()
Current_Time = millis();
if (Current_Time - Prev_Button_Time >= 8000); // shouldn't be able to get past here (quickly)
if (digitalRead(Request_Button) == LOW)
Button_Was_Pressed = true;
Prev_Button_Time = millis(); // assign right now to prev time
Serial.print(" button was pushed ");
// Check_For_Button();
alt_Check_For_Button();
Serial.println(" button was pushed ");
void alt_Check_For_Button() {
static unsigned long AfterTimer;
if (digitalRead(Request_Button) == LOW) {
if ((millis() - AfterTimer) >= (100)) { // Debounce time = 100
Serial.println("** button was pushed ");
_ATimer = millis(); // resets the timer while button is pressed prevents the delay timer from ever becoming true until button is released
MikeAmick:
Here's a debounce function that I use and it's rock solid:
// read a hardware button or switch. note that "pin" needs
// to be set as "pinMode (pin, INPUT_PULLUP);" and the button
// or switch pulls it to ground.
// returns 1 if button is pressed, 0 if not.
uint8_t getButton (int pin)
// adjust these to your needs. note that "debounce"
// must be greater than "threshold". 90% of "debounce"
// is a good value. Use 95 ... 99% for more stringent test.
// exec time is "debounce * 1 usec" plus small overhead.
#define DEBOUNCE 1000 // loop 1000 times (approx 1 msec)
#define THRESHOLD 900 // need at least 900 good reads
uint16_t n = 0;
uint16_t deb = DEBOUNCE;
if (digitalRead (pin)) {
return 0; // button up, return
// count "button pressed" state
while (deb--) {
n += digitalRead (pin) ? 0 : 1;
__builtin_avr_delay_cycles ((F_CPU / 1e6) * 1); // 1 usec
// if "button pressed" state more than
// "threshold" times, accept it
return (n < THRESHOLD) ? 0 : 1;
this allows you to press the button as fast as you would like (unless you need to press it more than 10 times a second) but won't bounce.
void Check_For_Button() {
