Why is this happening?
Here is my code, info below
 * LED Matrix
 * O = LED
 * Line = Pin
 * Vertical = Cathode
 * Horizontal = Anode
 * -OOOOO
 * -OOOOO
 * -OOOOO
 * -OOOOO
 * -OOOOO
 *  IIIII
 *  Matrix controlling pins: 53 - 43
 *  Y = 53 - 49
 *  X = 47 - 43
 *  Pin 48 is an input to control power
const int y1 = 53;
const int y2 = 52;
const int y3 = 51;
const int y4 = 50;
const int y5 = 49;
const int x1 = 47;
const int x2 = 46;
const int x3 = 45;
const int x4 = 44;
const int x5 = 43;
int Power = 0;
int GridPower = 0;
pinMode(48, INPUT);
pinMode(y1, OUTPUT);
pinMode(y2, OUTPUT);
pinMode(y3, OUTPUT);
pinMode(y4, OUTPUT);
pinMode(y5, OUTPUT);
pinMode(x1, OUTPUT);
pinMode(x2, OUTPUT);
pinMode(x3, OUTPUT);
pinMode(x4, OUTPUT);
pinMode(x5, OUTPUT);
void CheckPwr() {
  //This makes sure that the Power variable stays from 0 - 1\\
  if (Power > 1) {
    Power = 1;
  else if (Power < 0) {
    Power = 0;
void CheckGridPwr() {
  //This makes sure that the GridPower variable stays from 0 - 1\\
  if (GridPower > 1) {
    GridPower = 1;
  else if (Gridpower < 0) {
    GridPower = 0;
 CheckPwr();
 CheckGridPwr();
 if (Power = 0) {
  GridPower = 0;
 else if (Power = 1) {
  GridPower = 1;
So, the error its giving me is on the line, else if (Power < 0) {
and the error is
exit status 1
expected unqualified-id before ‘else’
 if (Power = 0) {
  GridPower = 0;
  GridPower = 1;
For one thing, you want == in these statements, NOT =.
For another, quit getting cute with the slashes in the comments. The backslash has special meaning.
    GridPower = 1;
    GridPower = 0;
Finally, case matters. GridPower is not the same variable as Gridpower.
