Smug
August 22, 2014, 12:41am
#1
The stepper motor should start sipnnig when sensor distance is <10, but it doesn’t, anyone???
#include <AccelStepper.h>
#include <NewPing.h>
#define TRIGGER_PIN 13
#define ECHO_PIN 12
#define MAX_DISTANCE 200
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
// Define some steppers and the pins the will use
AccelStepper stepper1(5, 8, 9, 10, 11);
int distancia [20];
stepper1.setMaxSpeed(1000.0);
stepper1.setAcceleration(1000.0);
void myDelay(long interval)
long init = millis();
while ((millis() - init) <= interval)
stepper1.stop();
void scanear()
int uS = sonar.ping();
int espaco = uS / US_ROUNDTRIP_CM ;
while(stepper1.distanceToGo() != 0){
if(espaco<10 ){
stepper1.moveTo(20048);
stepper1.run();
}//if2
}//while
Serial.println(espaco);
scanear();
MarkT
August 22, 2014, 12:45am
#2
You aren’t calling stepper1.run() in the right place - it needs to always be called.
Smug
August 22, 2014, 12:47am
#3
I called it, what would be the right place?
MarkT
August 22, 2014, 12:50am
#4
while(stepper1.distanceToGo() != 0){ <<<<<<<<<< relies on .run() being called
if(espaco<10 ){
stepper1.run(); <<<<<<<<<<<<<< won't necessarily get called
}//if2
<<<<<<<< move the call here and it will get called everytime.
}//while
Robin2
August 22, 2014, 10:21am
#6
Smug:
Still doesn't
May be true but is not very helpful.
Post your latest code !
...R
Smug
August 25, 2014, 5:21pm
#7
This program WORKS:
stepper1.moveTo(4096);
stepper1.run();
But when i put conditionals on it, the motor simply doesn’t move.
stepper1.run();
if(espaco>20){
fazer = 1;
if(espaco<20 && espaco !=0 )x++;{
distancia[x] = espaco;
posicao_motor1[x] = stepper1.currentPosition();
fazer = 0;
}while(fazer =1);
Any idea of what is going on and how to fix?
There are no errors at compling, and variables such as “espaco” are ok.
system
August 25, 2014, 5:26pm
#8
Translate it to english.
I would measure the input to see if the logic state matches your code. Are you using pullup or pulldown resistors ?
Post a schematic.
Smug
August 25, 2014, 5:36pm
#9
Well, i’m 100% sure that the wiring is ok, and i’m using a ultrasonic HC-SR04 sensor, “espaco” = space, that is the ultrasonic measuring.
if wou want the full code :
#define ECHO_PIN 12
stepper1.stop();
stepper1.run();
void scanear()
int espaco = uS / US_ROUNDTRIP_CM;
boolean fazer = 1;
int x = 0;
int posicao_motor1[20];
int distancia [20];
if(espaco>20){
fazer = 1;
fazer = 0;
}while(fazer =1);
scanear();
Robin2
August 25, 2014, 5:49pm
#10
Why are you starting another Thread about the same code as in this Thread
I recognized the strangely named function void myDelay(long interval)
I will ask the Moderator to merge the two Threads otherwise everyon is just wasting their time.
You posted a couple of lines of code
This program WORKS:
stepper1.run();
Why don't you post the full working sketch so we can all start from somewhere useful ?
My guess is that you are not using stepper1.run() properly in the code that is causing a problem - though why that should be in a function called myDelay() I have no idea.
...R
Smug
August 25, 2014, 5:59pm
#11
Well, i posted the full code up there.
system
August 25, 2014, 6:18pm
#12
Why is there an open curly brace after the ; that marks the end of the body of the if statement?
}while(fazer =1);
Why is there a while statement after the }? Why are you assigning a value to fazer using a while statement? What are you expecting to do while you are able to assign a value to fazer?
Robin2
August 25, 2014, 7:24pm
#13
Smug:
Where exactly? I don't see working code in any of your posts - yet you claim in Reply #6 to have a version with "This program WORKS:"
...R
system
August 25, 2014, 7:41pm
#14
Reply#6
This program WORKS:
first code block
second code block in Reply#6]
