All i’m doing is putting blank space on the serial monitor with
int bs = 5;// blank space;)
for (int i = 0;i < bs;i++){
There is a lot more before and after this snippet but this is just pure curiosity.
This is no a Leonardo by the way.
When bs = 1 the program size is 21622 and dynamic memory is 1432.
When bs = 2 the program size is 21626.
When bs = 3 the program size is 21630.
When bs = 4 the program size is 21634.
When bs = 5 the program size is 21638.
When bs = 6 the program size is 21642.
When bs = 7 the program size is 21632.???
When bs = 8 the program size is 21632.
When bs = 9 the program size is 21632.
Let’s skip ahead a bit.
When bs = 32767 the program size is 21632 and dynamic memory is 1432.
When bs = 32768 the program size is 19170 and dynamic memory is 900.(32,767 is the maximum “int” size so I can see it running into problems but that’s questionable.)
I was only planning on using 5 or 6 but for some reason the question popped in my head “Does it make a difference?” and as you can see it does.
My question is, what’s with the 4 byte difference in the beginning, no change for a while and then the sudden drop at the end?
