Why isn't my custom ATmega32u4 board detected by windows?
So I have made a custom ATmega32u4 board with onboard USB hub using FE1.1s IC. Now the hub part works flawless, but every time I connect it I get a message on windows saying "unknown USB device (descriptor request failed)" and it doesn't show up in Arduino IDE. I have flashed a Arduino Leonardo bootloader using an Arduino Uno as ISP. Any Idea why it fails to communicate via USB?
The files are here.
Micro_Rev1j.pdf (25.1 KB)
Evidently the USB thing isn't working as expected. Not an Arduino problem.
Help others help you by reading and following the instructions in the "How to get the best out of this forum" post, linked at the head of every forum category.
By the way, the ATmega32U4 supports USB directly, all by its tiny little self!
I know it supports USB, but I want to have a passthrough so that I don't lose the free USB port when using my board. If you look at the schematic of what I did, I used the FE1.1s as USB Splitter / hub and than just connected one of the USB outputs directly to the ATmega32u4 USB inputs. The other outputs of the FE1.1s USB hub IC work, so there is a problem with the ATmega mc and not with the USB hub part
So the problem is the ATmega32u4 doesn't communicate correctly with my PC via USB
Might be a good idea to post a schematic so the forum can see it directly.
done
