This may be a stupid question but whenever i enter a switch case and resume the IRremote through irrecv.resume(), it does not detect the buttons i press. Here is my code. For the "CH" and "CH+" cases, despite resuming the irrecv.resume() i still cannot detect it within the case. Only once the case breaks, it starts detecting the buttons i press.
#include <IRremote.h>
#include <Stepper.h>
#include <Servo.h>
#include <elapsedMillis.h>
const float STEPS_PER_REV = 32;
const float STEPS_PER_REV_OUT = 2048;
const int RECV_PIN = 2;
const int BUTTON = 4;
int Steps = 1;
int buttonstate;
int angle = 0;
int changer = 1;
Servo servo;
Stepper steppermotor(STEPS_PER_REV,8,10,9,11);
IRrecv irrecv(RECV_PIN);
decode_results results;
elapsedMillis timeElapsed;
pinMode(BUTTON,INPUT);
servo.attach(3);
irrecv.enableIRIn();
if(irrecv.decode(&results)){
switch(results.value){
case 0xFFA25D: //CH- : HALF TURN SERVO
Serial.print("CH-\nInitialising Servo Motor...\n");
while(angle != 180){
servo.write(angle);
angle++;
//delay(50);
Serial.print(angle);
Serial.print("\n");
Serial.print("Finished Servo Operation.\n");
angle = 0;
case 0xFF629D: //CH : STEP MOTOR OPERATION
Serial.print("CH\nInitialising Step Motor...\n");
while(timeElapsed < 10000){
buttonstate = digitalRead(BUTTON);
if(buttonstate == HIGH ){ //if button pressed, reverse direction or + button pressed */
Steps = Steps*(-1);
//delay(250);
irrecv.resume();
if (irrecv.decode(&results)){
Serial.print(results.value);
Serial.print("\n");
Serial.print("entered\n");
if(results.value == 0xFFA857){
Steps = Steps*(-1);
//delay(250);
if(Steps<0){
Serial.print("CCW\n");
else{
Serial.print("CW\n");
steppermotor.setSpeed(500);
steppermotor.step(Steps);
timeElapsed = 0;
Serial.print("Finished Step Operation.\n");
case 0xFFE21D: //CH+
Serial.print("CH+\n");
irrecv.resume();
while(timeElapsed < 5000){
Serial.print("\n");
irrecv.resume();
timeElapsed = 0;
case 0xFF22DD: //|<<
Serial.print("|<<\n");
case 0xFF02FD: //>>|
Serial.print(">>|\n");
case 0xFFC23D: //>||
Serial.print(">||\n");
case 0xFFE01F: //-
Serial.print("-\n");
case 0xFFA857: //+
Serial.print("+\n");
case 0xFF906F: //EQ
Serial.print("EQ\n");
case 0xFF6897: //0
Serial.print("0\n");
case 0xFF9867: //100+
Serial.print("100+\n");
case 0xFFB04F: //200+
Serial.print("200+\n");
case 0xFF30CF: //1
Serial.print("1\n");
case 0xFF18E7: //2
Serial.print("2\n");
case 0xFF7A85: //3
Serial.print("3\n");
case 0xFF10EF: //4
Serial.print("4\n");
case 0xFF38C7: //5
Serial.print("5\n");
case 0xFF5AA5: //6
Serial.print("6\n");
case 0xFF42BD: //7
Serial.print("7\n");
case 0xFF4AB5: //8
Serial.print("8\n");
case 0xFF52AD: //9
Serial.print("9\n");
irrecv.resume();
IRRemote.ino (3.8 KB)
