Why isn't this code working?
Hello!
So i tried to make a code that will light up some leds when i send 1,2 or 3 on the serial monitor forlater be used to light up the leds useing buttons on my xbox one controller with proceseing!
But it doesn't work :frowning:
  //put your setup code here, to run once:
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  int a = Serial.read();
  switch (a) {
    case 1:
      digitalWrite(3, HIGH);
      delay(2000);
      digitalWrite(3, LOW);
    case 2:
      digitalWrite(4, HIGH);
      delay(2000);
      digitalWrite(4, LOW);
    case 3:
      digitalWrite(5, HIGH);
      delay(2000);
      digitalWrite(5, LOW);
    default:
      //if nothing else matches, do the default
      //    default is optional
Thanks guys
case 1:
Try
case '1':
etc.
The serial input basics tutorial shows how to reliably receive data from the serial port.
I suspect your getting dirt characters in your serial stream and its turning of the lights before they get a chance to light up. Try limiting the received chars to the the decimal range for numbers in the ASCII table I.E. 48 to 57 asciitable
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  int option = 0;
  char a = Serial.read();
  if (a >= 48 && a <=57) {
      option = a.toInt();
      Serial.println(option);
  switch (option) {
    case 1:
      delay(2000);
    case 2:
      delay(2000);
    case 3:
      delay(2000);
    default:
Your case labels are looking for integers. They need to look for characters.
Try
   case '1':
etc.
It isn’t a good idea to just read the Serial port when you don’t know if a character has been read - and the vast majority of the time there won’t be one. However, in your case it won’t matter.
But to fix it, you should first check whether Serial.available() tells you that there is at least one character to read.
If you add this statement as the first statement in the loop() function, it will fix it. If there’s nothing to read it will just return from the loop() function and nothing will happen until at least one character arrives.
 if(Serial.available() < 1)return;
Pete
groundFungus:
i don't understad that post
Andreiva:
i don't understand that post
Did you follow the link and try to understand that thread?
el_supremo:
Try
   case '1':
etc.
Pete
I tried this but it doesn’t work :frowning:
adwsystems:
Yes and the guy uses more “voids” and i don’t understand that , i just want something simple.
I tried this but it doesn't work
Post the code that you tried.
Pete
KawasakiZx10r:
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  int option = 0;
      option = a.toInt();
  switch (option) {
    case 1:
      delay(2000);
    case 2:
      delay(2000);
    case 3:
      delay(2000);
    default:
Grown-ups write it   if (a >= '0' && a <= '9')
Try this, it may not be the correct way but it works.
But using delay for 2 seconds you can do nothing else
int a = 0;
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  if (Serial.available()) {
    a = Serial.parseInt();
    switch (a) {
      case 1:
        delay(2000);
      case 2:
        delay(2000);
      case 3:
        delay(2000);
      default:
        while (Serial.available() > 0) Serial.read();
el_supremo:
int a = 0;
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  switch (a) {
    case '1':
    case '2':
    case '3':
    default:
  switch (a) {
Have you forgotten something?
(Hint: what is the value of ‘a’?)
Thanks guys!
The code from Steveiboy worked like a charm!
Now i need to move on Processing :frowning:
Andreiva:
Thanks guys!
But do you understand why?
It is not enough to say it’s working, then go on to the next problem for someone else to solve.
A slight correction in your codes, and they work!
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
   //wait for interrupt to be made by Receiver Section of UART when character comes from Serial Monitor
void serialEvent()   //when a character comes from Serial Monitor, the MCU is interrupted, and it comes here
  byte a = Serial.read();
  switch (a)
    case '1':             //from Serial Monitor, you receive 0x31 for 1; so, must check for that ('1' or 0x31)
      delay(2000);
    case '2':
      delay(2000);
    case '3':
      delay(2000);
    default:
GolamMostafa:
Or you could ditch the utterly pointless serialEvent and save typing.
larryd:
If you say it like this ,idk because it looks similar to my last code
hmm
Andreiva:
hmm
I found the issue with my last code:
i was smart enoght to forget to type in
a = Serial.read;
I am so smart
a = Serial.read;But the compiler then reminded you that you aren't quite that smart.
