Why isn't this working? I'm trying to move a servo at 8 every day, but when I test my code nothing happens
/* Arduino example code to display a 24 hour time format clock on a TM1637 4 digit 7 segment display with a DS32321 RTC. More info: www.www.makerguides.com */
// Include the libraries:
#include "RTClib.h"
#include <TM1637Display.h>
#include <Servo.h>
// Define the connections pins:
#define CLK 2
#define DIO 3
#define CLOCK_INTERRUPT_PIN 4
Servo servo_0;
// Create rtc and display object:
RTC_DS3231 rtc;
TM1637Display display = TM1637Display(CLK, DIO);
servo_0.attach(0, 500, 2500);
// Begin serial communication at a baud rate of 9600:
// Wait for console opening:
delay(3000);
// Check if RTC is connected correctly:
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
while (1);
// Check if the RTC lost power and if so, set the time:
if (rtc.lostPower()) {
Serial.println("RTC lost power, lets set the time!");
// The following line sets the RTC to the date & time this sketch was compiled:
rtc.adjust(DateTime(2022, 2, 8, 7, 59, 55));
// This line sets the RTC with an explicit date & time, for example to set
// January 21, 2014 at 3am you would call:
//rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
rtc.clearAlarm(1);
rtc.clearAlarm(2);
rtc.writeSqwPinMode(DS3231_OFF);
if(!rtc.setAlarm1(
        rtc.now() + TimeSpan(10),
        DS3231_A1_Second // this mode triggers the alarm when the seconds match. See Doxygen for other options
    Serial.println("Error, alarm wasn't set!");
}else {
    Serial.println("Alarm will happen in 10 seconds!");
// Set the display brightness (0-7):
display.setBrightness(5);
// Clear the display:
display.clear();
// Get current date and time:
DateTime now = rtc.now();
// Create time format to display:
int displaytime = (now.hour() * 100) + now.minute();
if (now.hour() == 8) {
servo_0.write(180);
servo_0.write(0);
// Print displaytime to the Serial Monitor:
Serial.println(displaytime);
// Display the current time in 24 hour format with leading zeros enabled and a center colon:
display.showNumberDecEx(displaytime, 0b11100000, true);
// Remove the following lines of code if you want a static instead of a blinking center colon:
display.showNumberDec(displaytime, true); // Prints displaytime without center colon.
if(rtc.alarmFired(1)) {
    rtc.clearAlarm(1);
    Serial.println("Alarm cleared");
void onAlarm() {
Serial.println("Alarm occured!");
Please edit your post to add code tags (select and use "</>" editor button).
Most servo problems reported on this forum are power supply problems, usually caused by trying to power servos from the Arduino 5V pin. Use a separate power supply and don't forget to connect the grounds.
Please remove your code include the partial code tags and add it anew with code tags around your entire code.
You did nowhere use CLOCK_INTERRUPT_PIN nor onAlarm().
Please fix the link to your "More info" and check the code which you did not copy completely.
