Why my INTERRUPT doesn’t work
Hi.
I’m using an INTERRUPT for the 1st time. When I push the button it should stop the process and but now I have to hold the button to make it work //Mine is ESP32
Do you have any idea?
#define trigPin 32 //Trigger pin
#define echoPin 33 //Echo pin
#define LED 22 //LED
#define SW 18 //SWITCH
long duration, distance;
volatile bool sonicState;
void IRAM_ATTR isr();
portMUX_TYPE mux = portMUX_INITIALIZER_UNLOCKED;
void IRAM_ATTR handleInterrupt(){
portENTER_CRITICAL_ISR(&mux);
sonicState = !sonicState;
portEXIT_CRITICAL_ISR(&mux);
void setup(){
Serial.begin (115200);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(LED, OUTPUT);
pinMode(SW, INPUT);
attachInterrupt(digitalPinToInterrupt(SW), handleInterrupt, FALLING);
void loop(){
if(sonicState){
digitalWrite(trigPin, LOW);
delayMicroseconds(5);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1; //Convert the echo duration to distance in cm
Serial.println("Distance: " + String(distance) + " cm");
if (distance < 10) { //If distance is less than 10 cm will trigger the LED
digitalWrite(LED,HIGH);
else { //Else it will turn LED off
digitalWrite(LED,LOW);
delay(100);
how do you debounce the button?
Do you really need all that I/O specific code, just to toggle a variable?
Anyway, your button read is like a coin toss now, because it will respond to every microsecond long bounce of the switch contacts. So when you press it, it will go like on-off-on-off-on-off...off or on-off-on-off... on. The final state is finally reached when the contacts stop bouncing. That is why you need to "debounce".
