I'm using ESP32 WIFI MODULE. My problem is that once when I've saved wifi credentials using preferences. Now what i want to do is when i press a reset button( which is push button in my case) all the wifi credentials should be erased but i dont why my preferences is showing me wrong value it is not erasing the value. I am using attchInterrput for push button(reset button).. Here is my code may this will give a more clearance...
#include <WiFi.h>
#include <WiFiManager.h>
#include <preferences.h>
#define buttonPin 32 //Reset button
bool configure = 0;
Preferences pref;
WiFiManager wifiManager;
void YFC_READ(){ // This is reading and updating the value of configure variable
pref.begin("configure ", false);
configure = pref.getBool("configure ", configure );
pref.end();
dht.begin();
if (! rtc.begin())
Serial.println("Couldn't find RTC");
abort();
pinMode(dhtpin, INPUT);
pinMode(LATCH, OUTPUT);
pinMode(CLOCK, OUTPUT);
pinMode(DATA, OUTPUT);
pinMode(dig1, OUTPUT);
pinMode(dig2, OUTPUT);
pinMode(dig3, OUTPUT);
pinMode(dig4, OUTPUT);
pinMode(dp1, OUTPUT);
pinMode(25,INPUT_PULLUP);
pinMode(32,INPUT_PULLUP); // This one is the reset button and below is its interupt code
digitalWrite(33, HIGH);
digitalWrite(dig1, HIGH);
digitalWrite(dig2, HIGH);
digitalWrite(dig3, HIGH);
digitalWrite(dig4, HIGH);
attachInterrupt(buttonPin, freshMode, FALLING); // interrupt to reset button(push button)
YFC_READ(); //This is reading the configure variable
NVS_READ(); //This is for other variables
initWiFi(); //simple method to print something of 7 segment led
YFSE(); //simple method to print something of 7 segment led
delay(3000);
if(configure == 0){ // here for the first time i have to configure the wifi as configure variable is 0
//exit after config instead of connecting
wifiManager.setConfigPortalTimeout(45);
while(WiFi.status() != WL_CONNECTED ){
YFCND();
wifiManager.autoConnect("WIFI_CLOCK");
if(WiFi.status() == WL_CONNECTED){
YFCD(); //simple method to print something of 7 segment led
delay(1500);
timeClient.begin();
timeClient.update();
rtc.adjust(timeClient.getEpochTime());
configure = 1;
// here i'm updating the configure var so that next time i dont have to configure wifi again
pref.begin("configure");
pref.putBool("configure", configure);
pref.end();
}else{
YFNC();delay(1500); //simple methods to print something on 7 segment
IRTC();delay(1500);
}else if(configure == 1){ // here this will tell me to not to configure wifi again as configure = 1
if(!wifiManager.autoConnect("WIFI_CLOCK") && (millis() - startTime <= 5000)){
Serial.println("My confi is done, I'm waiting for WiFi..");
YFSC();delay(700);
timeClient.begin();
}else if(WiFi.status() != WL_CONNECTED){
YFNC();
delay(1500);
IRTC();
delay(1500);
Here what i want is when I configure wifi on esp32 first time it will update the variable configure = 1, and store the result in preferences and when i press reset button it will erase the variables value and let me configure the wifi again.. but after pressing reset button I'm getting the variable value as 1 please help
Thanksing you..
